neone know how to make a a/f screw adjuster?
I took my carbs off and cut slots in the screws. You can also make a tool by using some brass tubing about 2" long and flattening off one side. The adjustment screws are "D" shaped. You can also get an adjustment tool at Motion Pro. It is about 90 bucks. Factory honda version about 200 plus.
This is made for the VTX but it should work because its for the same d-shaped screw.
http://glensvtxgarage.com/aftool.html
