Need wheel bearing numbers
Old Aug 29, 2012 | 11:10 AM
MikeInCtown's Avatar
Default Need wheel bearing numbers
If anyone has bearing numbers for the rear wheel bearings, it would be greatly appreciated. i don't want the Honda, overpriced OEM numbers. The standard industry bearing numbers used by thousands of other products would be just fine.
I've noticed lately that there is a "clicking" that I can feel in the pegs on the bike. It's not dependent on engine RPMs, but more speed. I also notice it worsens a little when under heavier load, such as going up a hill or turning at some speed. I plan on checking the chain for a tight link, but I think with 47,000 miles on the bike, perhaps the bearings need to be replaced.
Old Aug 29, 2012 | 11:50 AM
JankCibberf2's Avatar
I just went on fleabay and ordered the all ***** bearings and they actually worked out pretty well. but hell i can't notice a difference in random parts
Old Aug 29, 2012 | 02:51 PM
Good info, thank you very much. Never thought to look for a kit. For $30 for everything i can't save much more than that. Now to get someone to remove the seals and bearings.
Old Aug 29, 2012 | 03:22 PM
adrenalnjunky's Avatar
Useful tool to have around if you're interested in pulling them yourself:
Blind Hole Bearing Puller - Needle Bearing Puller
Old Aug 29, 2012 | 09:26 PM
ya, or since your never using those bearings again, smack it with a socket extension and hammer or a screwdriver from the inside
Old Aug 30, 2012 | 07:49 AM
The biggest problem is that in some cases you can't. The front wheel for example has a spacer inside that won't allow you to smack it from the inside. Tried once. lol
Old Aug 30, 2012 | 08:11 AM
ah but my friend, you just werent creative enough. on the front wheel, tou use a very very tiny screwdriver and you'll notice that if you push up in the inside of the spacer it makes a small small small lip on the wheel bearing and then you smash it with a hammer! all things can be solved with a hamma haha
Old Aug 30, 2012 | 11:24 AM
Ditto - in the front wheel, if you have the bearings in so tight that you can't displace that spacer, they are incorrectly installed.
I've done front bearings with the drift-punch and hammer method before.
Reinstalled the new bearings with a pair of big sockets and a homemade press tool. (allthread and 1/8" plate.)
Now I'm actually kinda curious if the puller set I posted would work on our front wheels due to the spacer.
Biker Dude
Alternative Parts
Mar 19, 2013 05:51 PM
TBJack2011
F2 Tech
Feb 21, 2012 05:32 PM
marc0011
Nov 17, 2011 08:47 PM
dyracuse
Apr 15, 2010 04:51 PM
Nismo6RR714
Jun 18, 2007 12:54 PM
