need help!!!
im thinking of buying a 92 cbr f2 its been sitting since 2002 i wanna know what i need to get her running and if any one has any ideas on how much to reg. i know the throttle is stuck and the chain is rusty and a battery please any info would help thanx
carb clean=25-300 dollars depending on damage and if you will do it or mechanic will.
chain+sprocket= 150
throttle cables (push and pull) = 50
carb sync= again 20-100 dollars depending
new gas tank?=300
tires=250
new fluids=100
battery=60
oil filter =15
air filter 20-60
spark plugs=25
........ thats just the general stuff... if its broke, you will spend much more. plus you may want to do a valve adjustment
chain+sprocket= 150
new gas tank?=300
tires=250
new fluids=100
battery=60
oil filter =15
air filter 20-60
spark plugs=25
