Low compression???
After my 4 day head swap and more project I seem to be having an issue. I jumped a tooth on both cam gears. I then went in and reset the timing and whatnot. Now I have cylinders 1&2 at 90, 3 at 100, and 4 at 135. I think maybe I bent some valves but not sure cause I still seem to have ok compression. Any advice on how to check will be greatly appreciated. If you need more info let me know.
600, bad, cbr, cbr600rr, compresion, compression, conpression, f2, honda, low, motor, problems, signs
