left upper side fairing search
Old May 4, 2020 | 11:16 PM
CeCeF2's Avatar
Unhappy left upper side fairing search
Does someone have a fairing connection? any luck with overseas fearing kits? Thank you
Old May 5, 2020 | 11:42 AM
Phil314's Avatar
With fairing kits, you really get what you pay for cheap kits are cheap.
They rarely fit properly. They take a lot more work to make look even half way decent.
If you are replacing ALL the bodywork, there are 1/2 decent kits you can get.
Fiberglass is far better/more workable than ABS if you plan to repair or modify or customize the bodywork.
If you are only replacing a piece or couple of pieces.
Your best bet is to get stock body pieces. It will fit the best.
You'll probably have to paint it, since finding pieces that match your color scheme is getting rare.
Old May 7, 2020 | 11:44 PM
CeCeF2's Avatar
I ordered a front fairing nose upper cowl head fit from China. Hoping for the best. I only need to replace to left side upper cowl. I need to find the stickers that go on that piece. The pink flame and the CBR letters. Unsure how to acquire these decals....?
Old May 8, 2020 | 09:10 AM
Phil314's Avatar
Stickers can usually be ordered from online OEM suppliers like Ronayers.com or BikeBandit.com or local dealer.
However, with 25 yr old bikes, some parts no longer exist.
You'll need to know your bikes color code.
It's on a sticker on the frame of the rear tail section.
I think by the reg/rec, not 100% on that.
Old May 8, 2020 | 10:21 AM
Phil314's Avatar
ok, I had a few minutes, so I took a look.
I think your color code (92 black/blue/pink) is NH1 (Black base, type 11).
Looks like most of the sticker/decals are no longer available.
https://www.ronayers.com/oemparts/a/...0a3ff28/stripe
You might be able to have a vinyl graphics shop match them.
But that won't be cheap.
liquidengineer
Jul 6, 2008 08:50 PM
mitchedwards81
Mar 29, 2008 05:32 PM
