larger rotors of F2 rims
Old Sep 4, 2014 | 10:59 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by Stevis
I've got the Ferodo 310mm setup on my 1991 F2. The kit came with caliper reLocater brackets.
Stevis, I'm assuming you've had that kit for some time now, or is that one still available... I've personally never heard of it, as back in the day when these bikes were new, I wasn't riding Hondas.
Old Sep 4, 2014 | 05:55 PM
Phaedroah's Avatar
Good deal.
I'll look into the kit.
Thanks.
Old Sep 4, 2014 | 08:25 PM
coalminer frank's Avatar
Back in the mid 90's, before all this "dot com" stuff. I ordered stuff from a Dennis Kirk catalog. They had the Ferodo oversize rotor kit for F2's. I looked on their site the other day and didnt find anything as far as oversize. They have replacements and maybe a floating brake kit but not the oversize.
Old Sep 8, 2014 | 07:58 AM
Phaedroah's Avatar
I've had no luck finding the relocation brackets, either.
Someone is sitting on some leftovers, I'm sure...
Time to start watching EBay...
Old Sep 29, 2014 | 08:13 PM
Stevis's Avatar
Yeesh, apologies for the delay in answering...
Yes, I had bought these way back in the late 90's and had never mounted them until just recently. I had worn down my stock rotors below their minimum thickness, so it was time to mount em up. The bummer is that they are solid rotors, no floaters, so I think with the heat generated during race braking they would probably warp. But for street riding and the occasional track day they are working just fine.
Old Sep 30, 2014 | 10:16 AM
JNSRacing's Avatar
Well, the good news is that you have the brackets, and since those are also spacing out for 310mm rotors, I would think they would work fine with the EBC floating rotors - the rotors are not hard to come by, and if I remember correctly, the EBC part numbers are MD601LS and MD601RS.
By any chance do you know the Ferrdo part number for their brackets?
Old Oct 1, 2014 | 03:47 PM
Phaedroah's Avatar
As JNS says, those 310mm rotors are what are mounted to New Triumph Bonnevilles and its derivatives. In stock form, they are non floating, and while the 310mm floating EBC replacement rotors ain't cheap, but they are plentiful. ($179.99 each). I have one on my Bonnie.
I sure would like to find these offset caliper brackets. Talk about amazing braking potential!
Old Oct 2, 2014 | 10:51 AM
JNSRacing's Avatar
Indeed! I can speak from racing experience, that the stopping power is incredible!
I regularly have the rear wheel off the ground, when hard-braking for a corner entry... now I won't deny, that if a stock F2 brake system has calipers in good condition, rotors within service limits, good pads, good fluid, well bled, and stainless steel lines, you can get the rear wheel up anyway, BUT, the floating rotors in that larger size are better still, and will not warp under constant hard use, the way stock solid rotors can.
Old Oct 2, 2014 | 12:39 PM
I would think someone on this forum works in a machine shop or has a friend who works in a machine shop that has access to the proper materials, and could whip up a set of brackets for oversize rotors. I used to work in a machine shop, had access to the tools and material, and tons of titanium and aluminum.
Old Oct 3, 2014 | 02:38 PM
JNSRacing's Avatar
You're absolutely right, Frank, even without a CNC mill, these could be made.
I gotta say, a Titanium set would be super wicked, though a little pricier than aluminum... a Ti bracket set could help negate some of the weight that is gained overall, when using the larger rotors and brackets.
