larger rotors of F2 rims
I have the F2 front end and was told the 296mm rotors from the 1000cc Hurricane would bolt on but F3 calipers are required for braking.
Tried this but there isn't enough room for the F3 caliper to bolt to the fork, is there a way for this combination to work?
Making a set of caliper holders is an option but I was looking for a direct boly on solution.
Thanks Jim
Thanks Jim
All that said, If all your looking for is better braking, and don't want to perform a full transplant of the F3 front end (though these front ends do show up pretty affordable, here and there) you could install braided stainless steel lines, along with some good pads, purge all your old fluid, and bleed the system very well, with the new fluid - doing these things alone, for me, resulted in a "night and day" in difference braking, where the rear wheel sometimes comes up pretty regularly during hard braking.
Further, to reduce the rotors warping under consistent heavy braking (on track), I installed EBC 310mm floating rotors on my F2, using the EBC caliper relocation brackets to accomodate the new larger circumference...it looks sweet, too, I think anyway!! Check out my build thread below to see that setup.
Thanks JNS.
Read through you build thread, great work on the F2.
My plan was to install a set of F2 1991 forks on a CB900F for vintage racing using the F2 rim with larger rotors.
The vintage class restricts cartridge internals but Race Tech emulators are allowed, I have the Gold Valves, new springs, seals and bushings. I also have a 94 F2 set of forks but I don't think there are true/straight.
The pads are EBC HH with stainless lines on both F2 and F3 calipers
It looks like the best route is to follow your set up. The rotors look like ST1100's size.
I will likely sell off the 296mm solid rotors and pick up the 310 floaters, looks like a great setup.
Thanks again, Jim.
Thanks again, Jim.
I have a F2/F3 "Bitza" front end (F3 tubes, F3 cartridges, F2 lowers, F2 wheel and calipers), and am also looking for better braking.
Did you ever determine what "donor" bike the 310mm rotor comes off of? There is so much nonsense on Ebay, and the rest of the web, and most sellers don't really even know what they are selling, and offer "stock" photos, etc.
I have also had one heck of a time trying to find the EBC caliper relocation brackets (P/N: BRK15S).
Any leads on these?
Thanks-
Any leads on these?
Thanks-
You definitely will NOT have an easy time finding those - it seems like there is no availability,,, at all... ANYWHERE! Again, give EBC a call - maybe they'll have a line on some.
Well heck--if that's right, it'll be easy. The Bonneville/T100/and Scrambler all use a 310mm rotor, whereas the Thruxton uses a 320mm rotor.
I'll check on the bolt pattern, and post back on what I find.
Thanks for the info.
Update: You nailed it. The Triumph Bonneville (2001-on, but NOT the SE model) seems to share the same bolt spacing with the F2 front wheel. There may be other models that are the same, too. Now to find some caliper relocation brackets.
I can't believe how many pieces from a Honda fit the Bonneville. It's almost as if John Bloor sat down with the Honda executives and said, "I'm building a bare bones retro racer, and I need to make sure that it shares the geometry with a solid sport bike, because you know these Bonnie folks; they like to tinker."
I've got the Ferodo 310mm setup on my 1991 F2. The kit came with caliper reLocater brackets.
