jet kit qeustions????????
Old Apr 16, 2010 | 07:43 PM
dustinjklee's Avatar
Default jet kit qeustions????????
i was wondering ive noticed that on the dyno jet kits you have to xpoxy the hole by the needle jet on the diaphram. what is the point in this? do you have to do it or is it optional? and whats up with the slide drilling what is the point in this?
Old Apr 16, 2010 | 09:37 PM
jnicola's Avatar
Pure speculation, but it alters the amount of pressure caused when each cylinder intakes. You are SUPPOSED to do it, and it's extremely easy and no big deal.
Slide drilling is when you make those holes larger. It differs from application to application.
Old Apr 17, 2010 | 12:02 AM
so themdyno jet kit? and if so how does it work why doesnt the factory pro kit not have you doing this? so do you have the ? good? could you tell a difference?
Old Apr 17, 2010 | 12:21 AM
Sand.Man's Avatar
I've heard that the Factory Pro kit is a LOT better than Dyno Jet kits...
This is what I've been told by one of the best tuners in Canada:
Now some advice on your "jet kit" DO NOT go with dyno jet, you'll throw the needles away after much frustration. Order the Factory Pro kit. Yes I have their dyno, but I have installed MANY jet kits and tuned many, the FAC ones work much better.
Old Apr 17, 2010 | 01:38 AM
J-Dog-III's Avatar
I've got a Factory Pro jet kit in my bike, WAY better than a dyno jet kit by 1000% Factory Pro manufactures their jets better and will not wear your needle seats like dyno jet will.
I rejetted when i put a Carbon fiber Leo Vince and K&N air filter in and didn't even consider a Dynojet, i would just got for the Factory Pro, install needles, install jets, set float height, Adjust AF screws, sync carb's and be on your way. No need to drill slides and epoxy stuff
Old Apr 17, 2010 | 02:27 AM
jnicola's Avatar
What's your basis for comparison to the Dynojet kit?
The dynojet kit did wonders for my bike so I'm big on it. I have heard from some one I respect however that they don't like Dynojet as all their jet sizes and what not are proprietary.
Old Apr 17, 2010 | 09:12 AM
How exactly do u set the float height? Ive looked at it and dont see anything you can bend or really shim that wuld work good. How did you all set your float height?
Old Apr 17, 2010 | 09:14 AM
How did you all set ur float height? I couldnt see any good way to do it
Old Apr 20, 2010 | 10:29 AM
wiltse's Avatar
Default carb
I did the factory pro config 30 on my 94 f2 and the floats were not adjustable they are plastic tabs not adjustable metal ones. If you are reading a high level on your carb then check and see that the float bowl needle valve is sealing right.
Krux
May 4, 2010 08:04 PM
kreush33
Jun 4, 2006 01:43 PM
CBR1000RRMARINE
Feb 7, 2006 06:59 PM
