Fresh oil on plugs ?
Old Mar 16, 2014 | 03:00 AM
JamieDenny's Avatar
ok a leak test it is.
Having not completed one before how do I rule out the head gasket if I am doing that anyway because of the bubbles in coolant etc. Do I have to replace the gasket, rebuild and test again ?.
Thanks
Old Mar 16, 2014 | 09:05 AM
74demon's Avatar
If the gasket is blown, the leak down test will show it. You won't be able to test the rings on that cylinder due to the much bigger leak from the gasket. Use the results from the other cylinders to make a guess on the condition of the one with the gasket problem, if there is one.
You could also test the gasket with a hydrocarbon test of the cooling system. Its much easier to do. It looks for exhaust gasses in the cooling system.
Old Mar 16, 2014 | 01:37 PM
JamieDenny's Avatar
would I get the symptoms of oil on the plugs just from a head gasket or would it have to be the valve gasket or the other possible causes ?
Old Mar 16, 2014 | 05:23 PM
JamieDenny's Avatar
ok, just decided it probably not worth exploring any more on this engine.
my next big question is can I put a 96 F3 engine into the F2? I would still want to use the F2 carbs, boots, air box, wiring etc.. essentially just swap the engine straight in.
Found a corker of an engine but need to pick it up asap if i want it.
thanks
aaront1988
Mar 15, 2013 04:36 PM
CorruptFile
Aug 1, 2012 09:54 PM
redzintimidator
Apr 26, 2011 01:12 PM
Jimmy Dodge
Mar 8, 2011 08:09 PM
dmcb2120
Feb 24, 2010 10:36 PM
