Fork Seal Driver Question
Old Mar 17, 2010 | 12:22 PM
FuzzyWuzzyBear's Avatar
Default Fork Seal Driver Question
Quick question, did the obligatory searches. I know there's a way to buy a PVC pipe to replace a seal driver when replacing seals. What size pipe should I get for F2 forks?
Also, for replacing seals, do I have to completely break down the forks or is there a way to remove the seals after draining the oil without completely pulling everything apart?
Old Mar 17, 2010 | 02:04 PM
tundrafiend01's Avatar
F2 forks are 41mm which is about 1.61". See if you can find 1 3/4" pvc pipe and cut it to length.
If you're going to pull the forks apart, why not do a full service while you're at it?
Also, take some panty hose and rub the fork tubes down to make sure you don't have any rock knicks. If you do, sand them down. Otherwise, you'll be doing this again very soon.
Old Mar 17, 2010 | 02:24 PM
JimmyHoffa's Avatar
It is very likely you won't find pipe that diameter, but I use a fitting that has the right I.D. to clear the upper fork tubes, and I ground down the outside of to fit inside the lip of the fork legs.
Will.Bass
Aug 24, 2010 09:50 PM
jjennings153
Jun 18, 2009 08:54 AM
hawkwind
Nov 12, 2008 02:09 PM
ffjacobs
Jun 30, 2008 03:55 PM
wande00
Jul 25, 2006 07:16 AM
