Factory Jet settings
Old Apr 25, 2010 | 08:46 PM
C Average's Avatar
Default Factory Jet settings
I searched the forums and couldn't find this answer so excuse me if its on here but....
my f2 came with a yoshi slip on. from what I can tell there is no jet ket in the carbs because I read if there is there will be glue shrouds and it will be obvious. So my question is. How can I tell if I have a jet kit that was just not properly installed. and If I do I have factory jets in the carbs. then what settings should I use with the yoshi slip on. Right now the needle is 2nd from the top. and the mixtures where everywhere.
Old Apr 25, 2010 | 08:51 PM
C Average's Avatar
oh and I live at sea level in killa cali
Old Apr 25, 2010 | 09:40 PM
wiltse's Avatar
Default hmmm
if you have a jet kit your needle will have adjustments on the top.
Old Apr 25, 2010 | 10:10 PM
dustinjklee's Avatar
and if you dont have a jet kit put some #40 pilot jets and 130 main jets and its should scream. thats only if it doesnt have a jet kit. also only do this if you have a stock filter. k&n filters and slip on require like a 138 main jet
Old Apr 25, 2010 | 10:26 PM
C Average's Avatar
ok so the needles are adjustable. But I cant tell what size the jets are. Also I dont see glue anywhere ( where am I checking for glue again ). So im guessing it does have a jet kit. Ill take a picture.maybe someone can recognize the brand
Old Apr 25, 2010 | 10:29 PM
just because you have a jet kit doesnt mean anything is glued or drilled my factory pro jet kit doesnt require any of that. put the clip on the second notch from the top put a 130 main jet and a 140 pilot jet and i bet that **** will scream
Old Apr 25, 2010 | 11:23 PM
C Average's Avatar
the pilot jet says 38s the mains dont say anything
Old Apr 26, 2010 | 05:13 AM
yeah they do its probably on the side of the fatter piece
Old Apr 26, 2010 | 03:07 PM
C Average's Avatar
I removed every jet . and still nothing. all the pilot jets are 38s and the main jets are ALL SCRAPED so i cant read anytghin . I can see a K icon on them though. does this mean they are stalk being that the carbs are Keihin. and does anyone know the factory jet sizes both pilot and main ?
Old Apr 27, 2010 | 09:13 AM
Pilots are 38s and the mains are 135
