F2 Carb Removal
Old Mar 16, 2013 | 03:57 PM
jdub22's Avatar
Here is the intake.
Attached Thumbnails F2 Carb Removal-img_20130316_093732_570.jpg   F2 Carb Removal-img_20130316_093706_309.jpg   F2 Carb Removal-img_20130316_093700_205.jpg
Old Mar 17, 2013 | 02:31 AM
RedBaron's Avatar
Nah it looks ok jdub22 it won't affect performance, and you don't want anything falling down the intake.
Old Mar 25, 2013 | 12:36 PM
jdub22's Avatar
When cleaning the float bowls there was a white film that I sprayed carb cleaner on. I then scrubbed the float bowl. No matter what I did after the carb cleaner evaporated the white ghost film would return. Since I removed whatever was actually there I decided to put the bowls back on the carb. There was a lot of sand like gunk in the jets whatever that stuff was idk. So I took the jets out and sprayed carb cleaner through all of the tiny holes and screwed them back into the carburetor. I think the carbs are good to go! I hope I don't have to readjust anything in the carbs. I should be good since I didn't mess with the pilot screw adjustment. I attached some pics of what I encountered while in the carbs.
Attached Thumbnails F2 Carb Removal-img_20130316_232632_405.jpg   F2 Carb Removal-img_20130316_232625_071.jpg
95frankenF3
May 27, 2012 09:39 AM
403F4
Dec 26, 2011 01:53 AM
Motobean118
Apr 6, 2011 07:04 PM
kappa
May 4, 2008 09:29 PM
BRC223
May 3, 2006 04:06 PM
