coolant change
Old Jun 13, 2012 | 07:04 AM
jamescbr87's Avatar
Registered Users
Smile coolant change
is there a thread on how to flush and change the coolant
Old Jun 13, 2012 | 07:25 AM
JankCibberf2's Avatar
Step one, pull lower hose. Step 2 make mess. Step 3 connect hose, step 4 use hose from house and fill the radiator with water while it runs. Step 5 pull lower hose, step 6 make mess , step 7 connect hose, step 8 fill with coolant . Step 9 have EPA and your parents on your sss for making a deadly mess, step 10 go on Internet and ask how to remove coolant hose
Old Jun 13, 2012 | 09:05 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
You're a funny guy, Jank!! I f'n love it!!
Old Jun 13, 2012 | 11:29 AM
Haha why thank you my good man
Old Jun 13, 2012 | 02:32 PM
underground-mpyre's Avatar
On the water pump, lower left side of the motor below the stator is a bolt(10mm I think), unscrew that. The bolt is a above the hose mount a little to the right near the middle of the water pump cover. Only that one bolt needs to be removed. Pull the radiator cover cap off and drain into a pan. Then I recommend flushing it with a simple garden hose and watch all the 20 year old crap come out. Plug everything back up and fill it with coolant.
Old Jun 13, 2012 | 02:48 PM
74demon's Avatar
this one:
mine is stamped with a "C"
Old Jun 13, 2012 | 03:12 PM
Should be in the middle above the hose mount, not on the side like your pic. It looks like a side mounted drain plug in the middle of the water pump cover.
Old Jun 13, 2012 | 03:53 PM
Just don't over torque it!!
Old Jun 16, 2012 | 03:49 AM
jamescbr87's Avatar
Registered Users
Smile carb clean
i did a carb clean on my bike
i took out all the main jet and pilot jet and soked them into carb cleaner in a bowl for about half and hour ,took a took air compresser and blew into the littl holes on the pilot jet.
now i reinset all the jets and everything put back carbs and put bike together runs good
now was i suppose to put the jet and pilot jets back into the exact carb it came out of. are the jets and pilot jet diffrent sizes in each carburator
let me know. from what i heard the two inside carbs burn hotter then outside carbs
live4liftin
F2 Tech
Mar 18, 2010 07:14 PM
Ride Red Bull
Jan 20, 2009 09:33 PM
Glocker23
May 9, 2008 11:31 AM
rustler84
May 1, 2008 07:33 PM
9fiddyfo
Jan 20, 2006 10:56 PM
