Clutch rumbling, chattering noise
Hello all, I just purchased a clean 1993 CBR F2 with 23.5K miles. Everything is in good-great shape; I bought it off the second owner and the first was a woman. The bike has sat mostly for the last two years, but fires up and runs great. My main concern is a noise I am hearing when the bike idling. While sitting in neutral, the bike makes a rumbling, chattering noise. When I squeeze the clutch lever, it goes away entirely. I am reminded somewhat of the throwout bearing that made noise in a similar situation in my Mustang; however, that was more of a whistling noise. This is a low rumbling, chattering noise. Almost like a clothes dryer mixed with some pinging. Any ideas?
Thanks in advance,
Jon
Thanks in advance,
Jon
Most bikes make a bit of a chatter in neutral with the clutch out. It's generally from the plates rattling around in the basket with a bit of wear. Some are louder than others, and unless it's real bad... I wouldn't worry too much about it. A carb sync and new cct can help, but won't get rid of it entirely.
If you can get near another honda to compare with, that should ease your mind.![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
I've heard some that sounded like Kieth Moon going nuts with ball peen hammers on the inside of the clutch cover. lol...
BTW, Welcome to the forum.
Thanks guys. I will try and respond to all. I don't know if the CCT is stock. It doesn't sound like a chain rattle, however. Today I thought I heard the noise while cruising in third at about 30mph. The noise itself is not too bad, but it is noticeable. I agree with a loose-sounding clutch basket. I don't ride it too hard, as it is much more bike than my last (EX500).
Side question: What can I expect to pay for a valve adjust/carb sync? How do I know if I need one? The engine runs strong and sounds awesome.
