-   F2 Tech (https://cbrforum.com/forum/f2-tech-93/)
-   -   CCT Replacement (fix the engine rattle for good) (https://cbrforum.com/forum/f2-tech-93/cct-replacement-fix-engine-rattle-good-91238/)
city worker Jun 5, 2009 07:22 AM
the haynes manual I have makes this procedure look complicated. I have this exact noise commin from my bike. Gona lool into that APE.
Preid Jun 9, 2009 08:41 AM
Does anyone know where sells them in the uk? I've tried ebay and google and it only turns up guides on how to swap them out and youtube vids. :(
Also, does leaving it to rattle cause any damage?
My bike only rattles at 3krpm when warm, strange I know.
jun_cbrf4 Jun 22, 2009 04:52 PM
Cct
Originally Posted by Hershey (Post 769940)
So your bike is making a funny sound is it?
The intention of this thread is to clean up the F2 section of the never dying CCT reposts.
Almost all Honda’s have a few common shortcomings in their design, some of these include charging systems and most commonly the Hydraulic Cam Chain Tensioner (commonly referred to as the CCT).
http://img25.imageshack.us/img25/5742/hydcct.jpg
This tensioner is actuated by oil pressure, and while it is a great concept it is prone to failure.
The most common evidence of a failing CCT is a prominent rattle or ticking noise coming from the right side of the engine on a cold start (often mistaken for a noisy valve train), and the noise will go away when the engine reaches operating temperature and oil pressure is revived.
A completely seized CCT will always rattle.
In most cases replacing the old CCT with a new OEM hydraulic tensioner will yield unfathomable frustration when you go through the trouble of buying and replacing it - and the damn thing STILL rattles.
The BEST way to cure the problem is to purchase an “APE” manual CCT found on Ebay and other online retailers for about $50-70. You can also try your local dealership, but expect to pay more.
http://img25.imageshack.us/img25/3392/apecct.jpg
INSTALLATION INSTRUCTIONS:
Step 1: Remove right side tail fairing and right side lower fairing
Step 2: Locate the OEM CCT
Step 3: Remove black engine mount bracket if obstructing access
Step 4: Remove the 2 bolts securing the CCT to the engine
Step 5: If equipped with a steel gasket, clean gasket and save. If a paper gasket is present, scrape off gasket material being careful not to drop any into the opening or damage the gasket surface.
Step 6: Back the tensioner bolt all the way out on your new APE manual CCT, and apply a dab of white lithium grease or assembly lube to the end of the bolt.
Step 7: Install the new CCT and steel gasket or new paper gasket and secure it with the 2 bolts from the OEM CCT.
Step 8: Thread the tensioner bolt in FINGER TIGHT until your fingers cannot turn it any further (never use a wrench for this step)
Step 9: Lock the tensioner with the lock nut
Step 10: With the transmission in neutral and a cold engine, start the bike up
Step 11: If the rattle is present, unlock the lock nut and thread the tensioner clockwise until the noise is gone, then thread clockwise ¼ turn further
Step 11B: If the rattle is no longer present when engine is first started, unlock the lock nut and turn the tensioner counter-clockwise until the noise returns, then thread clockwise until no longer present and ¼ further
Step 12: Lock the lock nut, turn off the bike and put fairings back on.
Im having a difficult time looking for the CCT on my F2, Can someone post a picture please?
tundrafiend01 Jun 22, 2009 05:03 PM
Give me a couple of hours and I'll get you a pic. If you sit on the bike, it'll be on your right side, close to your knee. Easy to spot if you have the plastics off the bike.
EDIT:
http://impking.gotdns.com/EX500/imag...600f2/cct1.jpg
http://impking.gotdns.com/EX500/imag...600f2/cct2.jpg
http://impking.gotdns.com/EX500/imag...600f2/cct3.jpg
jpanside@gmail.com Jun 23, 2009 08:38 PM
tundra nice pics m8
but what is that toggle switch you got there? NOS?! :icon_no:
tundrafiend01 Jun 23, 2009 08:49 PM
Originally Posted by jpanside@gmail.com (Post 801516)
tundra nice pics m8
That's my ignition switch...building a track only bike..
theG Jun 24, 2009 03:23 PM
CCT adjustment..
I have a APE cct, and I followed the adjustment instructions to a Tee. But now i am wondering what the symptoms are of over tightening the CCT. Im pretty sure that i havent, but i would just like to know. thanks
Preid Jun 25, 2009 06:04 AM
I find when I pull the clutch in, the rattle stops all together. Doesnt appear at any rev's even if the bikes hot or cold.
Ive heard the rattling could be a leaf spring.
Can anyone back this up?
Sand.Man Jun 25, 2009 12:02 PM
A leaf spring? Does your CBR have a pickup truck rear suspension?
http://www.ironman4x4.com/images/sus...ringHeader.jpg
You're hearing the clutch plates rumbling, that's all.
tigertim20 Jul 3, 2009 01:15 AM
2 questions, 1, clutch plates rumbling, is this something to worry about? mine does it.....
second, i get the rattling on a cold start, goes away after 1 minute or less. it only happens sometimes. should i be putting this ape thing in? if so can you tell me where i could buy it in colorado? my father in law lives there and i could get him to send it to me. (i live in new zealand)
