Carburetor Cleaning & Tuning 101
Old Dec 28, 2010 | 02:18 PM
  #131
kinglee86's Avatar
i found a lime green gasoline in my carbs????? normal///////?????? never seen that color gas before
Old Dec 28, 2010 | 05:19 PM
  #132
Dissevered's Avatar
not sure what old corroded and stale gasoline will look like.
Is your air box clean? if your air box has green stuff in it, id be worried. Other wise just clean those carbs really well.
Old Dec 28, 2010 | 05:38 PM
  #133
kinglee86's Avatar
air filter was dirty...real dirty
Old Dec 28, 2010 | 08:27 PM
  #134
Dissevered's Avatar
That happens.
I wouldn't worry about it at this point. Clean the carbs (properly) and see how it runs.
Old Dec 30, 2010 | 02:16 PM
  #135
kinglee86's Avatar
where does the auto fuel vacuum tube hoook up too??
Old Dec 30, 2010 | 03:37 PM
  #136
adrenalnjunky's Avatar
you mean the vacuum line coming off the #1 carb? It connects to the petcock on the F2.
Old Dec 30, 2010 | 07:13 PM
  #137
skull rides's Avatar
1990 cbr 600f/stock
thanks for the lesson !
question?
having mine done as i post they will be ready bye sat
he did text and say carbs may run a little lean due to my yoshimura pipe
how do i adjust for that?
after there on and running my abox is stock as well
thanks
Old Dec 30, 2010 | 08:38 PM
  #138
kinglee86's Avatar
i downloaded a f2 manual off the net and it shows three holes under tank.. a fuel tube goes in the petcock, fuel tank drain tube, and fuel tank vent tube..so that line from carb 1...does it go to the gold piece right up under it????????
Old Dec 30, 2010 | 10:59 PM
  #139
Dissevered's Avatar
Originally Posted by skull rides
1990 cbr 600f/stock
question?
thanks
Do you have a jet kit installed? You can't do much tweaking otherwise. You could shim your needles up a tiny bit and turn out your idle screws. However I doubt you will need to do any tweaking for just a pipe. Ride it first and find out.
Old Dec 30, 2010 | 11:01 PM
  #140
Dissevered's Avatar
There are 2 holes on your petcock. one fat one (fuel) and one smaller one (vacuum). The 2 lines that come from the bottom of the gas tank aren't a big deal. They just lead to the ground.
