Carb sync problems
unless you've completely stripped the carbs down and cleaned every passage and jet and set the floats to the right height you havent cleaned the carbs. If you have done that then as said also check the air filter is clean.
If you bought the bike with an aftermarket exhaust system there is a chance the po changed the jetting so check the jets if you do the carbs again.
Also set the pilot screws back to standard setting.
get your manual here.
hondatech.info: Honda service manuals
It has a K&N filter and I think a full two brothers exhaust. I'm not sure if its jetted or not, what should I look for next time I pull them apart to see if its jetted? I guess I didn't clean that deep I just took off the bowls and took out the jets and blew air threw them and ran a wire. Everything looked pretty clean already but maybe it really wasnt. I turned the pilot screws out about 2.5 turns and Im not sure how to adjust the float levels.
I had no air filter and a two brothers, switched to a uni filter and 137.5 and 142. Id get rid of that k&n it let's in too much air and is a pos. Rip the carbs again and look at the main jets and see if there stock 130. If so rejet the mugs and don't waste your money on those stupid dyno jet kits like I did, you can buy our jets for 2 bucks a piece
Well Ive gotten it to run a little better with the pilot screws about 4 turns, is that drastic like its compensating for another problem? Its still a little hesitant off idle but I can at least ride it now and it also pops alot is that normal? Another problem has arose though the steering feels awkward like its hard to turn or like if a car isnt aligned.
4 turns is it extreme its definitely compensating. Vacuum leak maybe? Try shooting carb cleaner and diff spots of air filter or maybe where the carbs connect to the intake if these things have intakes..what does it just like connect to the valvetrain anyways
https://cbrforum.com/forum/f2-tech-9...c-tool-114927/
thats my next project once my bikes running what are you using to sync your carbs?
