Carb sync with home-made sync tool
Old 08-13-2010 | 05:13 PM
jmbiro2's Avatar
Where did you find the instructions for that tool? I am going to try to put one together this weekend. Nice work!
Old 08-13-2010 | 08:18 PM
super60daytona's Avatar
Wow, fancy. I just used a Radiator box (had to buy a rad for my car, it sprung a BIG leak). You even drew lines on your to judge by, I just eyed mine. I found the same with the adjustment screws and decided eyeballing it was as close as I was goint to get, even after swiching from water with red food color to ATF.
Old 08-14-2010 | 07:33 AM
compster's Avatar
Originally Posted by jesus1982002
where did u get the adapter screws? on mine i have 2 tubes that have nothing connected to it what are they?
It sounds like you might be missing a vacuum hose from #1 carb to the petcock. See the photo below.
BULK HOSE (3.5X1000)
95005-35001-20M
On my bike, #1 carb has a permanent tube with a vacuum hose connected back to the petcock (as shown in photo). #2 carb had the Boost Joint and Cap. Carbs #3 and 4 had screws that had to be removed and replaced with the Boost Joint. You need the cap and clip to seal them for normal use. The cap is removed when you attach your sync tool.
Below are the parts you need. If your setup is like mine, you need 2 of each part.
JOINT, BOOST
16214-MB0-000 $3.51
CAP, BOOST
16215-MV4-000 $2.13
CLIP, TUBE (B7)
95002-02070 $2.50
Old 08-14-2010 | 08:10 AM
compster's Avatar
I ended up making it based on a photo I found. There are a couple different instructions on the web, but I liked the one I used.
You need 20 feet of 3/16" ID tubing and two T connectors. I matched the diameter of the tubing to the T connector I was able to find. Ideally, you would use only one size of tubing, but because I could only find a certain size of T connector, I had to use another smaller size tubing and connect it the tubing on the board to connect properly to the carb. If you look at the photo at the beginning of this thread you'll see what I mean.
Presuming you can get a T connector to match, the ideal size tubing would be the same as the tube that connects from the petcock to carb #1 vacuum tube. I believe it was .17" internal diameter. 3/16 ID is probably too big.
I also bought a package of 1/4" coaxial nail-in clips to hold the hosing to the board.
I cut a 1'x3' piece of plywood.
Cut the tubing into 4 equal pieces (approx. 5' each). You also need a small piece to connect the T joints in the middle. Once connected, equalize the length of the tubes. You'll probably need to shorten the two middle ones a bit.
Once you have everything connected to the board, you need to suck the fluid you plan to use into the tube. It's best to do this in a vertical position and really easy if you have a vacuum tool. In any case, put one tube in the liquid and suck liquid in by mouth or tool until it levels out a bit below the the half way mark on your board.
Here is a useful site, but I didn't do the yard stick method.
http://www.airheads.org/content/view/183/56/
Old 09-23-2010 | 08:16 AM
patmetz's Avatar
Question MY CARB sync tool does NOT work right
I built one and it worked fine for about 5 min then sucked air into it and I have not been able to get ot it act normal since, I even went for motor oil in it to slow down the draw. I have for the short time used feeler gauges to get the bike running but I want to use my tool I built .
I put restrictors in it and I even bought aquarium valves to slow down the draw.Name:  DSCN0756.jpg
any Ideas? I really want this thing to work and HATE wasting money but I just need the tool to work. Or I have been looking at just getting some vacuum gauges.
Old 09-24-2010 | 09:53 AM
compster's Avatar
When you say "sucked air into it", do you mean there may be an air leak either in the tubing or the connection to the carbs.
Nice looking tool, by the way. Too bad it's not working. Kind of a strange place to store it though (in the bathroom) .
When I did my first sync, it was way out of wack and I had to be careful to not draw transmission fluid up into the carb vacuum port. Those carb screws are very sensitive. Otherwise , it worked perfectly.
Old 09-25-2010 | 03:54 AM
I attempted to reply via email, but it did not post. I had the same issue, I used zip ties at all the fittings. The engine creates enough vacuum to draw air between the hose and the fitting. Heat shrink may work and look better. I also found water to be too jumpy so I used Mex/Merc3, red for good vis and a good viscosity for the project.
Old 09-25-2010 | 10:10 PM
thedudeman's Avatar
Originally Posted by koko_TL1000R
.............I cannot understand - why you all you complicate things - you have to remove the carburettors to them apart to clean better - then before reattaching them to adjust the throttle position! these days I will make some pictures in the service of "bench" which I made myself for 1-2 hours - so I can give you an idea and to obtain a visual image - for easy and high quality way to repair ...................
Are you suggesting to "bench synch" the carbs? As in set the butterfly valves by eye?
That should be used only as a reference. Fine tuning by vacuum is the only way to get them perfect.
Old 09-26-2010 | 03:18 AM
antatious's Avatar
I beg to differ. When my carbs were out of wack, I synched them by eye. Once they looked equal, I put it back together and rode my bike and decided I should probably hook the manometer up to get it for sure in synch even though it felt good. After hooking up my manometer, I realized it was a waste of time because all 4 carbs were perfectly balanced
I probably got lucky. But with the carbs secure, and a lightsource shining through underneath them I got all the butterflys pretty identical.
Old 09-26-2010 | 04:25 PM
patmetz's Avatar
Unhappy
When I say sucked air into it it drew all of the fluid out of 1 of the channelsand got air into the fluid.
I replaced the oil with ATF and tried it again. I synced 3 and 4 using y connctors 2 into 1 and each to a carb. I then hooked all 4 up, while it did not suck fluid up this time I did manage to get the carbs synced at 1200 or so RPM but when I raised the RPMs it was all out of whack could this be that each carb is drawing against the others since they are all connected at the bottom? or bad valves it seems to run fine at higher RPMs?
wouldn't this be better if each had its own reseivor? I think I am going to buy a real carbsync tool as I have wasted 2 weekends jacking with this thing to save a few bucks.those I see have independent tubes or gauges. I think that is a big part of my issue.
Alot of the sputtering is gone but I still have some 2-5k and at idle with the sync done.
I just put new plugs but maybe I fouled one jacking around.
I am getting frustrated with this thing.
Quick Reply: Carb sync with home-made sync tool
