Carb Cleaning Update
Old Apr 15, 2012 | 08:34 AM
Tort93f2's Avatar
Default Carb Cleaning Update
Hi, I'm following Sticky's instruction on cleaning my carb. When I pulled the carbs off the intake I noticed one of the butterfly were dark or burnt from the obvious backfireing the bike was doing. I also noticed the on that same carb the "Pilot/Slow Jet Adjustment Screw" has a slit cut in the "D" shaped head that the PO(s) did to adjust the jet since he probably didn't have the "D" shaped tool for adjustments. When I unscrewed that one I could see the needle end was not quite as smooth and had very fine spiral marks on it, much different from the other needles on the jet.
My question is; do you think this jet should be replaced or will it be okay to put back in the carb?? Could this jet have affected the bikes performance? Thanks.
sk8er406
F2 Tech
Aug 8, 2011 10:44 AM
gruntworker
Sep 2, 2009 03:14 PM
WARDEN26
Aug 22, 2008 11:00 AM
mingstah
Jun 18, 2007 05:48 AM
plastikmelter
Dec 18, 2005 11:20 PM
