Can't catch a break
i only know of three hoses that I can see with the bike assembled theres one in the air filter thing but idk what that does and then theres two small and one big that connect to carbs, I know the big ones fuel now im just confusing myself >.<
Both breathers come out the bottom of the tank.
^I think you need to check your petcock again, disconnect fuel line, turn to on position, suck on vacuum line and fuel should flow out. Is that how you checked it last time?
Why would you need a spare key? I am assuming this means my key should not come out with it in the ON position? My key removes just as easily regardless of what position it is in. Once turned to the OFF position i do not need the key to turn it ON (anything will turn it), but it will not go into or out of LOCK without the key being inserted.
Juliet
The Hurricane Saloon
32
07-12-2009 05:30 PM
