Cam chain sneak peek
Old Jul 22, 2014 | 04:13 PM
Migge's Avatar
Default Cam chain sneak peek
Hey guys!
Quick question: would it be possible to open up the cover marked with a yellow circle in the picture and inspect the CCT and the status of the cam chain/cam chain guides without ruining anything? I mean, it would be simple to check that everything seems to be in order without doing that requires a major operation, right? I guess I'll have to fit a new gasket or something when I put the cover back, but other than that...?
Old Jul 22, 2014 | 05:50 PM
gtcole's Avatar
Welcome Crew
Just removing the cover is easy. Yes you will be able to see what you want in there. Only thing you would need to replace is the gasket. Or use rtv in a pinch. There's a pic in my thread with it removed so you can see what is visible with it off. Good luck
Old Jul 23, 2014 | 12:24 AM
Migge's Avatar
Thanks, gtcole! Just have to find a gasket then... Not easy in Sweden, and I'm looking at at least a week if I order from the UK. Well, minor problem, I'll just ride until then.
Old Jul 23, 2014 | 05:13 AM
NewSense45's Avatar
Maybe this site can help you find whichever parts you may need and the gasket...
OEM Parts : Babbitts Honda Parts House
Old Jul 23, 2014 | 05:43 AM
Migge's Avatar
Thanks! Will check them out. By the way, I was thinking of replacing my friction plates and maybe the steel plates while I'm at it, but most sets are EBC and the reviews both for the SRK and SRC kits are mixed. Any opinions?
Old Jul 23, 2014 | 11:42 AM
gtcole's Avatar
Welcome Crew
Oem is most peoples recommendation, mine included. Jns has some experience with aftermarket though, he will be more then willing to give ya an honest opinion, just can't remember which he has atm
Old Jul 23, 2014 | 02:40 PM
Migge's Avatar
Yeah, that's pretty much my conclusion too. I was just lazy and saw this EBC SBK-kit with springs, steel plates and friction plates. Figured it would be easy to replace. But then I thought some more and I don't really have that much of a problem with a slipping clutch so I figured I'll save me some money and buy it when it's becoming a real problem.
Old Jul 23, 2014 | 03:39 PM
Mattson's Avatar
You`d gotta spread the pack to see do you need new steels, they aren`t cheap and don`t always need changing.
Old Jul 23, 2014 | 05:59 PM
gtcole's Avatar
Welcome Crew
This ^ my bike had over 30k and all I needed was friction plates.
Old Jul 24, 2014 | 12:41 AM
Migge's Avatar
Mine has 70k+... But Mattson has a valid point as usual.
