brake pedal name?
Old Aug 1, 2011 | 10:08 PM
coldflood's Avatar
Default brake pedal name?
I broke my rear brake pedal assembly and bent the pedal. Was wondering if anyone knows where I can find a replacement. the rear brake step is whats broken off
...Any suggestions?
Old Aug 1, 2011 | 10:18 PM
Kuroshio's Avatar
Part # 46500-MV9-930 Pedal, RR Brake
Search someplace like ronayers.com, bikebandit.com or servicehonda.com by the part #
Old Aug 1, 2011 | 10:19 PM
kilgoretrout's Avatar
Administrator - Retired
Some people call it a rear brake lever, some call it a pedal. The pegs are called steps, too.
Ebay is usually your best bet on stuff like this if you can't find it in the classifieds.
Old Aug 1, 2011 | 10:36 PM
coldflood's Avatar
Ronayers came up with the cheapest original piece for $64. Then I found one on ebay with the whole master cylinder and step/pedal for $48, which is a little better. Is it possible to retrofit an other years to it. Or perhaps fit it with an f3 part.
The main reason I ask is because I found this on ebay:
Honda CBR1000FL 1991 Rear Brake Pedal & Carrier | eBay
Its only $20 dollars and has a cool looking step (maybe anodized), Also Kuroshio that part number just shows the pedal. I'm looking for the whole assembly. I'd buy this one (below) but its not up for 5 days :/
http://cgi.ebay.com/ebaymotors/F2-CB...Q5fAccessories
Old Aug 1, 2011 | 11:13 PM
F2 and F3 will be the same, but the 1000F ones won't fit.
Old Aug 2, 2011 | 07:21 AM
coldflood's Avatar
anyone ever considering welding a broken brake assembly back together?
Old Aug 2, 2011 | 10:28 PM
adrenalnjunky's Avatar
A pic would help. What are you referring to as the assembly? The pedal/lever is steel which is weldable, but if you broke the rearset (what mounts the pedal and master cylinder to the frame) then that's cast aluminum, and most likely won't weld up, and even if yougot it tacked together, I wouldn't trust it to hold your weight for long.
the parts are cheap on ebay or forum classifieds here and there just look around.
Old Aug 2, 2011 | 11:16 PM
coldflood's Avatar
yeah it was the part that mounts to the frame, I'll keep my eye out for a new one.
jstokes1445
Aug 27, 2009 02:51 PM
CBRHindle
Apr 30, 2008 09:29 AM
