Brake bleeding?
Old Nov 28, 2013 | 01:30 PM
Gary Evans's Avatar
Default Brake bleeding?
the bleed nipple on my front caliper isnt budging! is there another way to bleed it or do i need a replacement caliper?
Old Nov 28, 2013 | 02:26 PM
raylee's Avatar
Worst case scenario you could probably just drill it out and clean up the caliper.
Old Nov 28, 2013 | 07:27 PM
Bugkiller's Avatar
July 2014 ROTM
Default apply heat
Hi, try applying a bit of heat around the area then undoing it. As per other post drilling out is next option.
Old Dec 14, 2013 | 02:40 AM
asbjones's Avatar
also hit it with some wd40 or pb blaster and let it sit at least 15 min to soak into the threads
Old Dec 24, 2013 | 06:44 AM
MadHattr059's Avatar
Also, try using a 6-point socket, instead of a wrench. Less likely to round it that way.
Ern
Old Dec 24, 2013 | 07:17 AM
Mattson's Avatar
+1 on the six point socket or a six point box wrench, you'll most probably are going to have to replace the nipple, they are sold in just about anywhere that sells car or bike parts and costs a dime. Might have to get lock pliers and twist it out, I wouldn't use much heat cause it's so soft metal it's actually possible to melt it, let alone frying the seals or boiling the fluid. Once you're able to nudge it a bit like tapping the wrench with a hammer it usually comes out easily.
Old Dec 24, 2013 | 02:31 PM
Conrice's Avatar
Eat your Wheeties! Then give it a go.
But in all seriousness, post a picture of it. That would help to see whether or not it's corroded. I would put a 6 sided (not 12 sided) box end wrench on it. Then I'd find a way to add leverage (probably using a massive nut driver on the end of the wrench) to get it going. Put force on it, but make sure you're extremely controlled and GO SLOW - otherwise, you will for sure round that bleeder nut.
Don't be afraid to walk away from it for a bit if you start to get frustrated.
Old Dec 25, 2013 | 01:45 PM
wes 17's Avatar
Good tooling is essential, yes to the six point as others said and I`d even try to nip it tighter first, then give it a good whack to undo. It has to move eventually and at some time your gonna have to get serious with it and give it some grief. Worst thing that can happen is the head shear off. Even if that happens, its not the end of the world and can be sorted.
Best of luck mate
Old Aug 27, 2015 | 04:14 PM
optytrex's Avatar
In case anyone else here has this or a similar issue and will eventually replaced the seized bolt:
Get a sharp center punch tool and dig lightly (and straight) into the stuck, stripped, seized bolt with ONE firm hit. Once the center punch has a good hole in there to lever off of, lightly and repeatedly tap in the proper direction. DO NOT heavily pound on the bolt or you'll just end up further damaging it. Just many light taps with eventually prevail and it'll unwind in most instances where there's not too much corrosion involved. A peen hammer works real well here.
Or you can just use a sledge hammer after everything fails and extreme fustration sets in.....:icon_deadhors e:
switched
F2 Tech
Nov 20, 2010 09:27 PM
Black Rider
Nov 1, 2009 06:09 PM
WildWill
Feb 18, 2009 05:30 AM
dizzie56
Sep 12, 2007 07:03 PM
morpheous283
May 4, 2006 05:40 AM
