After market Tach issues
Old Feb 19, 2013 | 11:12 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by subyman1440
Ok, so I found out what was wrong. The Tachometer is broken! ... As I suspected, the tachometer itself is faulty. I confirmed it today...
That sucks, man... and I was going to ask where you got it, and at what price, but... don't think so now.
Some cheap knock-offs work out, but with electronics, I'm thinkin' usually it's of benefit to cough up the increased coins for the real deal!
For what it's worth, though, I hope they don't screw you around, and do get you a replacement, and right fast!
Hopefully you won't have any further issues, and it will yield accurate data, when you get it all sorted!
Old Feb 19, 2013 | 11:16 AM
JNSRacing's Avatar
I don't want to threadjack, subyman, but CJardine, how are you diggin' youre RX-2N? Are you using a sprocket sensor and speedo healer setup, or are you using a sensor on the front wheel? If you are using a magnetic sensor on the front, have you had a chance to test for MPH accruacy at all?
Old Feb 27, 2013 | 03:23 PM
MuthanLaw's Avatar
will that tach work for the f2??? thats a whole hell of a lot cheaper than the f4i tach
from an ebay posting: 11x1000 RPM LCD Digital Odometer Speedometer Tachometer Motorcycle w Backlight | eBay
sorry, I was wondering if this tach works..
Old Mar 17, 2013 | 01:00 PM
Spruytte0717's Avatar
Registered Users
I am trying to install these gauges right now and am having the same problem. The tach is not working. How did this turn out for you?
SquallCloud
Apr 18, 2014 07:09 PM
hillbilly86
Aug 11, 2013 12:44 PM
sjona2011
May 6, 2012 08:58 PM
Jave
Sep 11, 2009 10:34 AM
