Adjusting carbs for idle
Old 08-25-2011, 07:20 AM
coldflood's Avatar
Originally Posted by woo545
Well, you are just aimlessly adjusting the carbs. That's not going to yield optimum results. If you don't have a tach accurate down to 50 RPMs then you're basically stuck.
I used this for my tach.
Amazon.com: Actron CP7677 Automotive TroubleShooter - Digital Multimeter and Engine Analyzer: Automotive
but at $40, you are close to the $120. It's up to you whether you want to learn to do it yourself through trial and error (and end up with a new Multimeter) or have someone else do it for the $120. Really depends on you.
you can get a laser tach online for 15 bucks including S&H
Old 08-25-2011, 10:00 AM
woo545's Avatar
I'm curious, what would you measure? Everything that rotates would be concealed, right?
I needed a multimeter anyway.
Old 08-25-2011, 02:10 PM
MikeInCtown's Avatar
these are the lines i was talking about idk what they are or what they're for also what do you mean by passenger side?
The two hoses on either side of the middle hose aren't even on my bike. As far as I know in the second pic those vent tubes just sit there and do nothing. There is no place even in my air box to hook up. The middle hose goes to the breather at the back of the air box. the hose is probably got an L shaped bend in it and it just slides on when the airbox goes back on.
none of the hoses from the airbox are required to be hooked up when doing adjustments. The bike will wrun without the airbox on there at all.
Old 08-25-2011, 02:19 PM
coldflood's Avatar
cool, thanks for clearing that up
Old 08-25-2011, 06:48 PM
MadHattr059's Avatar
This is the real deal, very cool device. Well thought out.
Ordered mine last Sunday, got it Wednesday.
Harmonizer Vacuum Multi-Tool -- It ain't your Daddy's Twinmax - ADVrider
Ern
ddavis17
03-18-2012 08:28 AM
hnda900rr1
07-21-2009 07:45 PM
ClassicCBR
08-19-2008 02:34 PM
woo545
10-03-2007 12:34 PM
SoCal_600RR
06-01-2006 04:20 AM
Quick Reply: Adjusting carbs for idle
