'91 CBR 600 tail conversion help please!!
Old Dec 24, 2012 | 05:01 PM
babybrandish's Avatar
New Member
Smile '91 CBR 600 tail conversion help please!!
Hi guys iv just bought a cbr 600 91 streetfighter but has the old looking tail with banana seat and i knows theres loads of threads on this but cant find much info out on how to do it etc.. if i got a cbr rr tail and seats or r6 something newer and 2 seats will it go on the cbr sub frame or do i need a new sub frame? also where would the panels bolt onto would i need to make brackets etc and as its single seat and i get rider and pillion seat with new tail how would these bolt on as the old seat is alot dif? any help much appriciated please thanks in advance guys
Old Dec 25, 2012 | 11:30 AM
adrenalnjunky's Avatar
You'll have to fabricate the mounting points and stuff - making brackets out of steel or aluminum channel or angle iron.
There is no one way to do it, as everyone fabricates their stuff a little differently based on their skill and tools and what they have laying around for materials. Read through a couple of the fairing swap threads and look at the pictures posted - should give you a starting point.
Old Feb 10, 2013 | 11:13 PM
streetfighter2012's Avatar
i have a 92 f2 and put a 03 cbr rr rear tail fairing on it and looks sick te bike is still in mock up, but came out sick, you need to cut the rear of the frame off and get 1inch tubing if you grind the edges slightly it will slip in tight with a hamer and bend the tubes once there welded, i used 1 inch with a .25 wall for the strenght. then you need to make mounts for the front its not hard you just need to be willing to go for it, once you cut it your commited, you need a inegrated tailight, a rear seat cover and also need to be willing to cut you stock seat id post pics for ya but i cant figure out how to
Old Feb 11, 2013 | 03:20 AM
richbransby's Avatar
where the box is that you write in, theres a little picture above, a square, kind of a yellow scene with a mountain in front of it???
Well, upload your photo to photobucket or any photo hosting website, itll give you an image url. click that box, a pop up box will appear and copy the url link into that pop up box and itll upload the picture for you.
Please do this! i really wanna see how you did this as ive bought the same items and now im scratching my head as to what to do!
Old Feb 11, 2013 | 09:42 AM
subyman1440's Avatar
An 04-05 1000RR tail will fit without cutting the fairing or subframe. However, you will need to make custom mounts for the 4 brackets that hold it up. If you want, I can take pics of my tail swap once I get home. Btw, mines a bit sloppy but it gets the job done lol. The R/R does get in the way. So I only have 3 of the 4 mounts on.
Old Feb 11, 2013 | 10:33 PM
rich i uploaded a few photos of my bike in the mock up stage most of the tail for you check them out in my profile
Old Feb 18, 2013 | 10:53 PM
campos_motorsports's Avatar
Post some pics man. I have a 04 1000rr tail that I want to use for my bike. How did you attach the rear seat? Did you buy the latch and all or what did you do?
cds83
Jul 3, 2013 12:05 AM
Kaptain
Jan 6, 2013 10:39 PM
TripsD
Sep 4, 2007 05:39 PM
krazyasian04
Apr 6, 2007 04:19 PM
Jhamblett
Mar 9, 2007 04:44 PM
