180 55 zr17 on rear of f2??
Old Aug 13, 2010 | 12:30 AM
hot83chevy's Avatar
Default 180 55 zr17 on rear of f2??
ok ive heard rumors u can mount up a 180 55 on the rear of a f2 with no modification?? who can verify this. before i buy a new tire for no reason! thanks
Old Sep 16, 2010 | 09:24 AM
doose-doe's Avatar
I run it on mine with no issues
Old Sep 16, 2010 | 10:33 AM
thedudeman's Avatar
Even if it fit without rubbing the chain (I don't know if it would or not), I would NOT recommend it on the stock rim. Its far too narrow for that wide of a tire. The tread profile will be pinched and the tire won't handle (lean in) as it was designed.
Old Sep 16, 2010 | 02:29 PM
NYKnick1015's Avatar
i wouldnt try it with an f2 rim... it would fit but the tire would be out of shape... i would upgrade the rim to an f3 rim so it spreads out wider especially with the chain
Old Sep 16, 2010 | 03:07 PM
thedudeman's Avatar
The F3 rim still isn't as wide as a rim should be for a 180 tire. But it will be closer.
For anyone that's done it: Does the F3 rim retain the same sprocket location? i.e. are their any alignment issues between the front and rear sprockets?
Old Sep 16, 2010 | 10:56 PM
yea it still retains the same sprocket location... same distance across with the bearings
Old Sep 17, 2010 | 07:44 AM
thedudeman's Avatar
Okay, cool. good to know
Old Sep 17, 2010 | 09:18 AM
doose-doe's Avatar
I have no wear issues, bead issues, rubbing issues or performance issues. I can lean the bike over more then my buddies with stock size tires on their sv650 (160) and triumph tripple (180). The only issues I have is the tire likes to slide because its a hard compound tire. But its the only tire I had to put on at tthe time. no regrets
Old Sep 19, 2010 | 06:18 PM
FNQuickF2's Avatar
Read this thread..
https://cbrforum.com/forum/f2-tech-93/goin-up-bigger-wheel-back-114015/
firstbike
Nov 3, 2008 05:00 PM
