drag rcing tips
RE: drag rcing tips
Feather the clutch
Keep the front end down
Unless you're bike's stretched, a burnout is not really necessary.
Trial and errorwill help achievewhat you're comfortable with for launch RPM's ( I start at low RPM's and, aftereach run,increase RPM's by 500 until I see my 60' bottom out)
A shallow stage gives you "more" reaction time....sort of
Heat kills the clutch plates so don't feather it too much and leave plenty of cool-down time in between runs.
I usually tuck the instant my clutch is fully engaged.
Don't practice power shifting just yet....hone your 60' before trying any fancy stuff.
RE: drag rcing tips
When trying to get your best passes, between runs, park the bike.
Give the plates time to cool.
I've used a logbook to log each pass. reaction time,launch rpm,temp, 60ft, 1/8, 1/4, mph's.etc. After a while the numbers will start to add up. Takes away the guessing.
FarAway
FarAway
