Drag Racing Raced a guy from a light? Been to a night at the track?? Tell your story here.
Drag Race
Old May 9, 2006 | 04:29 AM
cbr_racin123's Avatar
Default Drag Race
So anyone into or looking to get into drag racin.
Lets hear about mods you have done to set up your bike for the drag track.
Old May 10, 2006 | 06:18 PM
Black's Avatar
Default RE: Drag Race
Sprockets changed up, reverse shift (one up, five down; quicker shifts).
Other than that, I'm a light little dude, so that might help out.
Old May 10, 2006 | 08:49 PM
Cool, I have mine about ready for the track. I have a 10 inch over swing arm, and about everything else done. Motor, tranny and I can't wait to see how it works out. Just need to find time to put the quick shifter on, and set it up. Mine is set up for the drag track. should be fun I will post results when I get there. Right now I am busy running my car, but the bike will be next.
Old May 10, 2006 | 09:03 PM
QuinC's Avatar
with the quick shifters you put on, are those the ones where you dont have to let go of the throttle or use the clutch? or they just 1 up 5 down?
Old May 10, 2006 | 10:56 PM
Yes, full throttle up shifts. Cuts the ignition for that split second.
Old May 17, 2006 | 12:46 PM
Redline954's Avatar
I've got the extentions on the swingarm, lowered, air shifter, full exhaust, and a 190 shinko rear tire...ran a 9.8 at the track. I am now having problems with my air shifter...every time I use it the bike kills and won't start. The fuse for the fuel pump blows and I have to change it. Any ideas what could cause this. It started after someone hit my air shifter button when the bike was off. This is a '02 954 by the way.
Old Aug 30, 2006 | 01:47 PM
turbof4i's Avatar
TURBO. slammed. strapped.
Old Aug 30, 2006 | 04:03 PM
WILDPAIR's Avatar
3 to 9 swingarm, head done, 39mm flatslides, lowered, rc wheels, 2 brothers pipe and header, tranny, and looking to put nos on here in the next few weeks. still having some carb problems but working on that.
Old Aug 30, 2006 | 08:01 PM
bindelsf2's Avatar
yoshimura exhaust, lowered, 5 degree timing advancer, front strap, steering stabilizer, avon semi-slick tire,
swingarm +6" is going to be done soon and NOS [sm=nxsmile.gif] is on the way!!
Old Sep 1, 2006 | 10:15 AM
ClutchBurningRacing's Avatar
2003 cbr1100xx bored out, JE pistons and rings, Falicon rods, cnc'd deck and block, pro cut tranny, stage IV injectors and fuel rail, fmu, 2 stage turbo, cable clutch conversion, Trac 10 over arm, Pingle air shifter, lock-up clutch, Wave rotor, Air Tech 8 over glass tail, Air Tech glass race tank, Zero Gravity screen, Dyna shift light, Shiko 003 190 rear and low profile front, Schnitz front strap.
Mods in the works
clutch basket, dual ball bearing turbo, boost control, cut forks, RC wheels
any and donations are welcome!
