Detailing Discuss detailing your ride within.
paint removal
Old May 14, 2007 | 10:48 PM
StreetInsanity's Avatar
Default paint removal
ok well i bought my bike off a girl and it has a crappy paintjob .plus its a powder blue i want it gone.what should i use to remove all the paint without messing up the plastic? thanks for the info.
Old May 15, 2007 | 02:29 PM
hurayta's Avatar
Default RE: paint removal
I assume you plan to repaint it? If so, a normal paint prep job, sanding, sanding and more sanding is all you need to do.
Old May 15, 2007 | 10:33 PM
what grit # should i use ....sorry never done anything like this before.
Old May 19, 2007 | 04:21 AM
urandaman's Avatar
if you trust the previous prep work. just sand it down with 320 first to get it to look dull then sand it with 600 and you should be ready for your base coat of whatever color you want
Old Jun 12, 2007 | 06:46 PM
Lmag954RR's Avatar
Use aircraft remover take it off. Read about polishing rims. Same concept just your taking the paint off the fairing instead of the polishin.
Old Jun 26, 2007 | 11:22 AM
corys35's Avatar
i dont think aircraft stripper on plastic is a good idea. just sand so its nice and smooth. that aircraft stripper might eat up all your fairings, try it out on some plastic first and see what happens
Old Jun 27, 2007 | 06:42 AM
txsmainevent's Avatar
ARE U F*CKIN SERIOUS? AIRCRAFT STRIPPER? lmag maybe u need to step away from the fairings and call a prof. if u use the stripper ur gonna eat right threw ur fairings and then ull be replacing them. 320 grit? ur kiddin right? streetinsanity get about 800 grit, then move to 1000, 1500, 2000 grit. u dont want to scratch the hell outta ur fairings u just want to take the clear coat off then go back wit some primer to cover the blue until u get it painted. trust me if u want to replace ur fairings cuz of holes from the stripper go ahead, and 320 is to rough. ur not sandin metal here your sanding plastic.
Old Jun 27, 2007 | 08:29 AM
Gringo's Avatar
I concur.
Old Aug 19, 2007 | 01:27 PM
Pastrulo's Avatar
How about Carb Cleaner? That stuff takes the paint right off, i don't know the side effects of doing this, any experts?
Old Aug 26, 2007 | 04:33 AM
demonchild's Avatar
do not use chemicals on plastic. I agree with pimpn on this one, except to make the job go faster start with 400 grit and 2000 is most likely unnessasary. On my last bike I sanded with 1000 for the final prep, cleaned with dishsoap water and shot the paint. Came out perfect.
