Detailing Discuss detailing your ride within.
How to do a good rattle can paint job
Old Mar 7, 2009 | 04:56 PM
court18's Avatar
Default How to do a good rattle can paint job
I want to repaint the plastics and gas tank. I was going to paint it glossy black. I am just wondering how to get the best results that I can. so any tips are welcomed.
Old Mar 7, 2009 | 05:57 PM
platnumbob's Avatar
If you want a decent paint job that will last I would suggest not using a rattle can. Use a gun and compressor and make sure you spend the prep time before you paint.
Old Mar 8, 2009 | 04:45 AM
daazndood's Avatar
you cant(or shouldnt) rattle can a gastank. something about rattlecans not having a catalyst so if you spill gasoline on it, the paint will shrivel off
Old Mar 8, 2009 | 08:52 AM
Rickracer's Avatar
Walmart and NAPA both have cheap "air chargeable" paint guns that will allow you to mix up and use catalyzed automotive primer and paint. That would be my recommendation.
Old Mar 8, 2009 | 08:24 PM
camaropower's Avatar
Its true, I rattle canned mine and even with a clear coat, gas will eat it away
Old Mar 9, 2009 | 11:48 AM
diguise88's Avatar
simple answer, there is no such thing as a good rattle can paint job
Old Mar 10, 2009 | 08:31 AM
a040599's Avatar
I have a question to add to this... Will the new series by duplicolor (I think) that requires no mixing work? It comes in standard colors and is available on the shelf in quart cans. I want to be sure since this is the route I was going to take but do not know if it has the catalyst that you guys are speaking of.
Micah
Old Mar 10, 2009 | 12:53 PM
Honda_Runner's Avatar
do you have anymore info on these air chargeable paint guns, i did a search on walmart and napa and did not come up with anything.
thanks
Old Mar 11, 2009 | 09:12 AM
Rickracer's Avatar
I had to check with my buddy the painter for a brand name, which is Preval, this is the website: http://www.prevalspraygun.com/automotive.htm , here's some for sale: http://www.jamestowndistributors.com...ct.do?pid=2155
Old Mar 13, 2009 | 10:46 PM
anybody know anything about these self powered air units, i saw one a harbor freight the other day. thought it might be worth a try. here it the kit.
High Volume, Low Pressure Spray Gun Kit
http://www.harborfreight.com/cpi/cta...emnumber=44677
and thanks Rickracer for the info.
