Is this bad?
Where are you riding that you need to clean it 2 hours, every time you ride!?[&:] As long as you're not using any harsh solvents you're fine. Water and soap or stuff like Honda Spray Polish is all you need.
What you could do is wash it once with a soap you would use for dishes. These soaps have degreasers in them and will cut wax and contaminants off your bike. Then you want to clay bar it and get the rest of the gunk out of it. Then use a good canuba wax. After that you want to use a qaulity car wash when you want to wash the bike. These are designed to keep the waxes on your paint. I re wax every 5 or so washes I may hit it with a quick detail wax in between. This will help keep your clear coat safe.
I feel that there is no harm done as I clean my bike after every ride also. I usually use Honda Spray polish a do a wax job on the 4th ride/cleaning. I probably only have to spend 20-40 minutes on each clening though as compared to your 2 hours.....
-John
-John
