Frame`
Look here
http://madison.craigslist.org/mcy/1446772091.html
And here
http://madison.craigslist.org/mcy/1446777430.html
these are near me if you need a looky see on them. I could use a few parts off them also.
And here
Just be a little careful. I wanted a frame for mine & found out they were quite cheap. $250. The only problem is that it's illegal to change the frame unless you have the rego for that frame. Also most frames are bent anyway if the bike is being parted. Having them straightened properly is also quite cheap ($300) & retains all the original strength & no hassles. These days it's done with motor still in the frame.
If you do change the frame make sure that you go over it with a fine tooth comb looking for any signs of impact, warpage or cracked paint. These are tell tale signs of a possible bent frame.
captain crash
May 17, 2010 06:30 PM
