Would someone mind taking a look at the wiring diagram and confirm this?
I need to remove the clutch and side stand circuits because my mini buggy has neither a side stand nor a way to signal a clutch switch. If I'm reading this wiring diagram correctly both circuits just require a short to bypass them, so I'm pulled the wiring all the way back to the main junction and and soldered the green/white stripe, green/red stripe, and green wires together.
Would this effectively bypass both circuits?
https://i.imgur.com/IgaWqqF.jpg
