What tire pressures do you guys run front and rear?
Old Jun 4, 2011 | 11:14 PM
Steve Theodore's Avatar
Default What tire pressures do you guys run front and rear?
I just picked up my 954RR today and the turn-in feel was extremely sluggish compared to my other motorcycle, which surprised me. I rode it home and made it safely, then checked the tire pressures as soon as I could and was horrified to find that the front had about 10 pounds of pressure in it. So, naturally that will explain the unbelievably poor steering feel.
What pressures do you guys run front and rear on your 954s? I believe I have stock sized tires (noticed a 120 on the front) but will double check if that makes a big difference. Thanks in advance!
Old Jun 5, 2011 | 12:10 AM
letsride's Avatar
Depends on the tires you have.On the street,I run 32-f 34-R.On the track I'll go down a few lbs.depends on track temp.
Old Jun 5, 2011 | 01:12 AM
Cool...that's about the range I was aiming for. I'm not as savvy with motorcycle maintenance and care yet, and was unable to find the recommended pressures on the tires themselves. Needless to say I'll be making sure that both front and rear are in the 30 pound range before taking my new bike for a spin tomorrow.
The irony is that I was a bit shaken by how unstable my 954RR felt so it was somewhat of a relief (after the initial horror wore off due to safety reasons) to find out that the pressure was so far off. I'm sure the bike is going to feel a hell of a lot better on my next ride!
Old Jun 5, 2011 | 05:58 PM
No big surprise, but after a ride today I'm happy to provide the follow-up report that at 32f, 34r the bike feels much more stable, predictable, and safe. Thanks again for your inputs.
Old Jun 6, 2011 | 04:51 PM
moosestang's Avatar
What kind of tires are on the bike? Some tires turn in all by themselves and other are stubborn. I had pirelli corsa 3's on my buell and they did not like to lean over. Switched to Michelin pilot power 2ct's and they are the complete opposite. I have regular pilot powers on the 954 and they turn in easier than the pirellis, but not quite as quick as the 2cts.
I usually run 35psi front and rear on both my bikes.
Old Jun 7, 2011 | 08:34 PM
I checked today and the tires in question are Dunlop Sportmax D208s. The front is a 120 and the rear is a 190, so they do appear to be the stock sizes.
Old Jun 8, 2011 | 09:04 AM
backdoc's Avatar
Your regular PP's are the same tire as the 2CT so turn in should be the same. Only difference is the softer compound near the edge of the 2CT. The center compound and profile are the same. Most riders are confused by this and buy the 2CT and never get to the egde of the tire to even use the softer compound.
I run 34/34 in Michelin Pure's and so far they feel great.
Old Jun 8, 2011 | 02:14 PM
ajzcamaro's Avatar
32/34 is what Im running I believe. Is your rear tire a 190/50 or 190/55?
Old Jun 8, 2011 | 08:12 PM
120/70/17 front
190/50/17 rear
Old Jun 9, 2011 | 08:07 AM
moosestang's Avatar
I can almost feel when I get to the softer rubber on the 2ct's. I swear it feels like the rear gives a little. Even in the mountains of NC, I could not use all of the 190/50/17 on the Honda. I had the 2ct's to the edge here in Florida!
