What OIL do you use?
Just bought four liters of the repsol full synthetic. Wanted the royal purple bought all the places that sell it are out, and i needed an oil change before Sundays ride. Any one want to share what they know? Does Full syn help reduce engine temp? I have heard of it actually in creaseing temp in some bikes. Any and all input is much obliged.
Mine seem to heat up a little more with full syn. Nothing worth talking about though. The bike runs much smoother now that I've switched to Mobil 1 full syn.
Make sure you change your filter too
mobil 1 full syn 10w-40... and i see your pretty new so id also like to suggest you use the search function. someof themost highly debated topics that have been covered over and over and over again are; which tires are best ,which grade gas to ue and which oil is best
Okay okay, old topic. Dammit, i thought i was on to something. I do appreciate the "fresh, i just baked it this morning" advice. So...thank you. seems like a lot of members in the stale advice history under the FUAQ section were using mobil, as well as a couple of you. Well i put in the repsol, i like it. temp drops ARE significant and worth the switch. However still running hot here in AZ, in traffic. can't fix that i guess...unless i change over to nitrogen filled Michelins, and maybe some "octane booster" in the "VP Racing fuel" that i run regularly. That should "cool" things down. I was running the castrol that stuff is no bueno man. I can now aggree that it is better to spend more on quality oil.
PS. Still wont buy the Mobil. Just wont....thats why.
