strange sound. 02 954 swap
well, i can't see the facebook pic (i don't have a facebook), but if they have it itemized on there, then i guess i'd trust them. and that would make sense if labor is not included. the outer basket costs about $300, the inner $100, then all of your plates, springs, etc. then an oil change (because they have to drain it).... it just doesn't leave all that much room for labor.
well, if they really did replace the basket, my guess would be those bearings...
personally i would call them and refuse to ride it back to them because it could damage anything more. They could then bring a trailer to pick it up. it shouldnt have left there that way. also id double check what they replaced. often times, it is about time to change the basket when the plates go because heat has warped the basket which means the new plates springs etc wont sit correctly and thus making sound when it is idling.
i still can't believe they let the thing leave there making those sounds. if i had a shop, that thing would not have left. i would have talked about this with you before you even left after dropping it off.
first, it's an opportunity for them to make more money (by fixing the damn thing) - unless you specifically told them not to fix the misfire.
second, the sound doesn't appear to have changed at all... which means they didn't fix it. i couldn't have, in good conscience, handed you a bill.
riding with a misfire alone is not a good idea. it causes a lot of wear on the rest of the motor, unwanted drag on the misfiring cylinder, and really ****ty power transfer through the clutch and the tranny
hell, it could have caused that with the clutch issue to begin with.
Ok, so i disassembled the seat gas tank and airbox. Guess what I found....
Not only does my fuel pressure regulator drip, it squirts a steady stream or fuel. Usually when one goes out it drips when you pressurize the fuelrail. That would explain the noise it , would also explain the bad gas milage, the richness of the A/F ratio, the gas smell, the bad idle, the bogging down, the misfire, and the fouled spark plugs i just found. I ordered 4 stock spark plugs, fuel pressure regulator, and some carbon breaking down cleaner for my gas.. Also, my clutch and all is fine no sounds/grinds or any other nasty noises. If this doesnt fix it i will go ballistic i think this brings my bill to about 750$ on cluding clutch plugs regulator and all. I am absolutely sick of $hit breaking.
Posted a video also
Posted a video also
So taking apart my bike for the 1st time I discovered a lot of things, bad fuel regulator, fouled spark plugs, power commander wasn't plugged into the main fuel injector harness, dirty air filter, there was so much fuel leaking into the cylinders that there was fuel in top on the valve when I looked down the velocity stack.all in all I'd say I learned a ton about my bike .
you have got to be ****ting me... that's bad man, previous owners suck sometimes.
what do you mean? like residue? or puddled? and do you mean on the butterfly valve? you shouldn't be able to see the actual valve from the airbox. or did you pry open the butterfly valve on the TB, and look all the way down in there? do you have a picture of it? bad FPRs can definitely cause the injectors to act up because of the pressure never being constant. have you checked your oil? does it smell like gasoline? i'm not saying it will, but if you have tons of gas leaking into the cylinders, it definitely *could* be leaking past the rings when the motor is off.... which would kill the viscosity of the oil, creating more problems
that's the only way man. you wrench, you learn. hopefully the fuel pressure reg fixes your motor issues. i'd love for it to be something simple for you. new plugs and a new FPR would be great if that fixes it. but i'm not sure it'll fix the clutch issue.
