Steering Damper
Has anyone tried using the 1000rr steering damper on a 954 because of the lack of a damper that the 954 has. I would like to get a stabilizer damper but dont want to spend almost 500 on one so does anyone have any suggestions on using one from a differentbike. I was thinking about getting one from a R1 or gsxr since those wrap around the forks. I would guess tho that a 1000rr would be better since its honda on honda
I like to hear more on this option, IMO its a much cleaner look when its mounted on the bottom or lower end of the triple. If anybody has anymore info please let us know i.e. such as using a stock gsxr damper or an aftermarket one, if so what model aftermarket especially for $100.
This is the kit.
CBR F4i/F4 owners with 929/954 Front End -Damper Bracket kit Ho - $79.00 : HoHey Designs, Custom and Factory Parts for stunt bikes
Steering Damper
04-05 GSXR 600 750 STOCK STEERING DAMPENER STABILIZER | eBay
With gsxr damper,I suggest you drain the fluid and replace with 15w or 20w fork oil.Stock is 5w and is too soft.
Steering Damper
Unless you are taking you and the bike to the edge a lot, there's not much call for
a stabilizer, imo. The purpose of them is to enable high-speed riding at the edge of the performance envelope. So if you stunt or race, yeah, this is the tool for you.
The only real-world use is the occassional 'tank-slapper' head-shake.
The most common cause of a head-shake is setting the front tire back down after either a cresting-hill hop, striking road-derbis or a wheelie.
If you ride responsibly (most of the time, at least! lol), except for hitting deer/dogs,
it's not a common issue. Most of the front end issues, at these speeds, should
be addressed on a case-by-case basis. i.e. tire balance, fork alignment, etc.
So, even though it can help, it's a 'final-touch' kinda up-grade, in terms of bang-for-buck. If you aren't riding the hard-line-at the edge-all of the time, I'd buy a new saddle first. Now that will boost the bonding between you and your bike. ;-)
Ern
Ern
