Stats for 2003 cbr 954
Manufacturer
Honda
Model Year
2003
Model
CBR®954RR
MSRP
$10,599.00*
POWERTRAIN
Engine
954cc liquid-cooled inline four-cylinder, DOHC; four valves per cylinder
Displacement
954cc
Bore x Stroke
75.0mm x 54.0mm
Compression Ratio
11.5:1
DRIVETRAIN
Carburetion
Programmed Fuel Injection (PGM-FI) with automatic enricher circuit
Ignition
Computer-controlled digital with three-dimensional mapping
Transmission
Close-ratio six-speed
Final Drive
#530 O-ring-sealed chain
DIMENSIONS
Wheelbase
55.1 in.
Seat Height
32.1 in.
Dry Weight
370.0 lbs.
Fuel Capacity
4.8 gal. (Including 0.9-gal. reserve)
COLOR OPTIONS
Colors
Black/Red
Metallic Titanium/Black
BRAKES / WHEELS / TIRES
Suspension
Front: 43mm inverted HMASâ„¢ cartridge fork with spring-preload, rebound and comp.-damping adj.; 4.3-inch travel
Rear: HMAS Pro-Link® single shock with spring-preload, rebound and comp.-damping adjust.; 5.3-inch travel
Brakes
Front: Dual full-floating 330mm discs with four-piston calipers
Rear: Single 220mm disc with single-piston caliper
Tires
Front: 120/70 ZR-17 radial
Rear: 190/50ZR-17 radial
Model:
Honda CBR 954 RR
Year:
2002
Category:
Sport
Engine and transmission
Displacement:
954.00 ccm (58.21 cubic inches)
Engine type:
In-line four
Stroke:
Compression:
11.5:1
Bore x stroke:
75.0 x 54.0 mm (3.0 x 2.1 inches)
Cooling system:
Liquid
Gearbox:
6-speed
Transmission type
final drive:
Chain
Physical measures
Dry weight:
167.8 kg (369.9 pounds)
Seat height:
815 mm (32.1 inches) If adjustable, lowest setting.
Wheelbase:
1,400 mm (55.1 inches)
Chassis and dimensions
Front suspension travel:
120 mm (4.7 inches)
Rear suspension travel:
135 mm (5.3 inches)
Front tyre dimensions:
120/70-ZR17
Rear tyre dimensions:
190/50-ZR17
Front brakes:
Dual disc
Front brakes diameter:
330 mm (13.0 inches)
Rear brakes:
Single disc
Rear brakes diameter:
220 mm (8.7 inches)
Speed and acceleration
Other specifications
Fuel capacity:
21.80 litres (5.76 gallons)
Reserve fuel capacity:
4.00 litres (1.06 gallons)
As far as i can tell the bikes are exactly the same both years claiming 131 hp
