Starting problems...
Probably redirecting air to it somehow.Have not bypassed the tip over sensor yet.Went out on a ride today but did not have an issue this time.Mine happens maybe 3 or 4 times a year.
Yeah mine is every time the bike gets nice and hot. I'm wondering if I can use some heat shielding, etc to help block the heat. But I don't know if it has to be bolted to the frame as a ground or something.
Did you pull the vacuum line off the fuel pressure regulator? If it has gas inside it, then that's a sign it's bad. It's most likely some kind of fuel issue.
Well if that's the case, then i suspect it's the battery or the starter. I don't know how easy these are to push start, but if that works, then you can rule out a fuel problem.
Any pics of the fuel line are you talking about? I haven't pulled the vacuum line on the FPR since I replaced it 2,000 miles ago with a oem replacement. I also replaced the battery about 300 miles ago so it's fine. I'll try to get some video up of both hot and cold start ups. I cant remember if my bike turns over slower or not when hot. If it does I think it's only slightly slower.
Mine did it again yesterday after some very hard track laps.Go out for a few laps go every thing very hot shut off bike for 5 min.Tried to restart and would just crank over but no start.Push starting always started.
