Starting the bike during winter
Old Dec 10, 2012 | 05:50 PM
Dazed's Avatar
Default Starting the bike during winter
Will this keep the battery charged and the fluids flowing? I start it about once a week, and have a full tank of gas, I'm not worried about engine moisture people say that is mostly on older bikes to worry about.
Old Dec 10, 2012 | 08:25 PM
Sebastionbear1's Avatar
Depends on how long you run it.
A couple of minutes no, but 10 to 15 minutes it will recharge somewhat but still eventually lose charge over the winter period.
Best bet is to get a smart trickle charger, which charges, then 'tops up' the battery as needed.
I use a Ctek
Website Motorcycle Battery Chargers - Full Range Order Online - Ctek Battery Chargers
Cheers, SB
Old Dec 11, 2012 | 01:47 AM
Hudson's Avatar
A trickle charger is by far the best investment during winter, i would start the bike up for about 15 mins but not to recharge the battery (that level of time will not do this anyway) i would start it up just to get the fluids flowing through the pipes etc of the bike, move the tyres around so the pads don't bind etc etc, if you can go for a quick spin on the road when the weather is dry and ok then all the better, but i have mine on an Optimate and it has never failed to start, i just start it a couple of times and run it for about 20 mins or take it out for 30 mins on the road if its not raining or there is ice etc on the road.
Old Dec 11, 2012 | 07:46 AM
Conrice's Avatar
idk about you guys, but i found 2 trickle chargers at my local goodwill (with quick connects) for $10 each.
so it doesn't have to be a huge cost. just keep your eyes peeled! definitely get a trickle charger.
not that i live up north, but i can imagine that if you have a half full gas tank and you heat the bike all the way up, when it cools back down to your cold outside temp, wouldn't that cause moisture to get in the gas tank?
Old Dec 11, 2012 | 10:49 AM
Dazed's Avatar
Moisture in the tank maybe yes. Where can I find new bolts that hold down the seat. mine are about to strip out that's why i dont want to take my seat off again to charge it
Old Dec 11, 2012 | 11:19 AM
Conrice's Avatar
any hardware store. i think they're 8mm /1.0 thread pitch.... but that's memory talking. just take one with you and you can get it
Old Dec 11, 2012 | 12:29 PM
BadS1's Avatar
Best thing is not to start it. Older or new doesn't matter,its cumbustion and in return makes condensation unless ridden for a complete heat cycle it will build inside. I have Battery Tenders....(name brand) that have a pigtail that stays on the battery and I plug in without removing the seat. I have them on my 954 and 600RR.
Old Dec 12, 2012 | 12:07 PM
maverick0716's Avatar
Definitely the best way to go. I've always been told that once you store it, leave it stored until you're ready to ride again. Also the battery tenders with the removable pigtail connectors like you said are awesome. I have mine bolted to my battery terminals. I fed the wires up under my rear seat so all I have to do to connect to the charger is open the rear seat.
Old Dec 12, 2012 | 01:45 PM
Mattson's Avatar
I`ve heard that if the bike is stored in a dry, warm place it`s good to give it a few revs every once in a while, say once in a month. to get the fluids going
Old Dec 12, 2012 | 03:23 PM
BadS1's Avatar
Still condensation..... doesn't matter how warm it is or cold. Storage is storage.
