Slip on conversion
Old Jul 11, 2007 | 04:42 PM
PitbullF4i's Avatar
Default Slip on conversion
Ihavent even looked into this at all but i have noticed a few 954's with slip ons, not bolt ons, do you have to change the header to put on a slip on? or can you just chop off the bolt up part?
Old Jul 11, 2007 | 04:51 PM
Triax's Avatar
Default RE: Slip on conversion
I believe if they have what looks to be a slip on its more than likely a full system. The bolt ons are attached just like the stock canister with three bolts at the bottom of the canister
Old Jul 11, 2007 | 06:20 PM
bobjoezx's Avatar
slip on and bolt on are same thing, just depends on maker and stuff.... full system is different
Old Jul 12, 2007 | 09:50 AM
Triax's Avatar
I agree but if you look at the exhaust he has its a full because a slip on for a 954 is technically a bolt on exhaust canister.
Old Jul 12, 2007 | 06:01 PM
CBRinPDX's Avatar
I have an Erion Racing canister bolted onto my stock system. One thing to think about is the HTEV valve. It seems strange but it actuall is beneficial to the system. So either leave the systemit alone, use a quality bolt-on or high-end full racing system. This is what I was told by Erion Racing. I'm thinking they are a reputable source....
Old Jul 12, 2007 | 06:06 PM
bobjoezx's Avatar
if u get a full system and remove the htev dealio good idea to get a tune and air fuel ratio worked out again, but a slip on is really just for noise and doens't do much, there is just less baffle/packing
Old Jul 12, 2007 | 08:33 PM
PitbullF4i's Avatar
i would just like to change it to a high pipe, i dont need a full system.
Old Jul 12, 2007 | 09:34 PM
bobjoezx's Avatar
so find a high rise system
Old Jul 12, 2007 | 09:37 PM
joey954rr's Avatar
ORIGINAL: bobjoezx
+1 yea dude if you arnt looking for more power just get another slip on...
Old Jul 13, 2007 | 01:43 PM
PitbullF4i's Avatar
thats what im trying to find out, is there such a thing as a bolt-on high pipe? or do you have to modify the stock header (cut the bolt-on part off) to make it work?
