Shock Bottom
Old Feb 9, 2009 | 01:10 PM
Getz2003's Avatar
Default Shock Bottom
Comin down off wheelies or at least me attempting them it feels like the front shocks are almost bottoming out. Never felt like this on any of my 600's.....Any help on what I can do or should do?
Old Feb 9, 2009 | 10:37 PM
Diablo Runner's Avatar
Have you noticed the seals leaking at all?
Old Feb 10, 2009 | 07:30 AM
Getz2003's Avatar
Naw, No leaks around the seals. The two screws on top of the tree????Willl that do anything as far as adjusting pressure in the forks???
Old Feb 10, 2009 | 10:30 AM
repsolroger's Avatar
put some zip ties around your fork tubes. and when you do a wheely just check out were they end up at.
i have no problem cause i only do 3-4 inch power wheelies :-)
Old Feb 10, 2009 | 05:43 PM
letsride's Avatar
try adjusting your preload to full hard,it sounds like it might be too soft and bottoms out when you land.
Old Feb 11, 2009 | 06:07 PM
Getz2003's Avatar
I messed with the preload, and it helped. I did notice a simaler screw to the preload screws at the bottom of the forks at the axle ends. Any clue what these are?
Old Feb 11, 2009 | 10:44 PM
letsride's Avatar
those are for compression damping
Old Feb 11, 2009 | 10:58 PM
letsride's Avatar
And if you still don't know what it does.I suggest you read your owners manual or the service manual.It's the way to set up your suspension.
Old Feb 12, 2009 | 06:49 PM
i agree with letsride... reading sometimes does wonders...
Old Feb 12, 2009 | 07:04 PM
Getz2003's Avatar
As soon as I get one I will do that. If my bike would have came with it I prob would have went there first....
