Seeking the electrically advanced
Old May 25, 2024 | 01:25 PM
Bimmersandblades's Avatar
Default Seeking the electrically advanced
I won’t bore you with too many details but I bought a really low mile but non running 954 that’s turned out to be a basket case. Everything I touch breaks something else it seems. I’ve spent more time undoing things than I have diagnosing. Today I removed the tail fairing to check the relays. I lost my dash lcd and have power other places. I also started blowing the 10A turn stop horn fuses. Overall, I’d like to get it back to cranking, i was not getting spark and thinks it’s a greater wiring issue causing all of this.
Any help is greatly appreciated
Old May 25, 2024 | 11:33 PM
dannoxyz's Avatar
How are you “checking” things?
What do you mean by “more time undoing things”?
With these old bikes, you have to follow physician’s credo, “Do no harm!”
To troubleshoot electrical issues, you must do passive, non-interference testing and measuring only. Do not change anything. Do not “fix” anything until you’ve positively 100% for sure identified an actual problem because your measured numbers is not same as what manual says it should be.
So yes… in order to put your bike back to original as-received condition with just “cranking, and not getting any spark”, list every single change you made in chronological order. From looking at list, we can determine order to undo things to revert it back to less critical state.
Also let’s start with some effective troubleshooting (fastest, least effort and least costly). Passive, non-interference measurements only:
1. Measure battery power with everything OFF, volts=???
2. Measure red/wht wire under engine-stop relay, volts=???
3. Measure resistance between engine-stop relay red/org wire to chassis-ground, ohms=???
4. Key ON, stop-switch=RUN, measure power at engine-stop relay blk wire, volts=???
5. Measure power at engine-stop relay output blk/wht wire, volts=???
6. Unplug one ignition coil and measure power at harness-plug’s blk/wht wire, volts=???
That’s good enough for now, this is usually 5-min fix with multimeter. I’ve helped over 100 people fix their no-start, no pump-prime problems in far-off remote dark parking-lots via phone in middle of night. Many of them in pouring rain!
K0622763
Sep 15, 2016 10:05 AM
Steve Theodore
May 30, 2012 09:54 PM
dont_fear_the_Reaper
Aug 11, 2011 12:08 PM
belfasthurricane
Apr 19, 2010 08:02 PM
VP
Nov 9, 2006 07:25 PM
