Seat Bolts
Old Aug 11, 2012 | 12:59 PM
Dazed's Avatar
Default Seat Bolts
The two bolts underneath the seat on my bike seem to be different on is a allen bolt and one is a socket bolt.
The allen bolt is almost stripped out, So I'm trying to figure out how I can take the bolt off to get to the battery??
Old Aug 12, 2012 | 01:07 PM
Hudson's Avatar
They both should be the same and they are sort of star bolts, mine were a bit crappy too so i replaced both, but if one is stripped it may be a bit of a job given the angle you need to be in to get at it.
Old Aug 12, 2012 | 04:52 PM
Conrice's Avatar
they only need to have the same thread pitch and size, it doesn't matter at all what head they have...
what i would do, is get your allen on it and ready to go, then with your other hand use a pair of pliers around the outside of the bolt. then using both the allen key and the pliers, slowly and firmly start to twist. be careful not to make it worse. i know it's a bitch with the seat, but you should be able to make that work.
go down to ace or true value and replace them with whatever kind of bolt you want. allen, nut, - whatever so long as its the right thread and pitch (which i think is m8 1.0 if memory serves). get stainless as to avoid them rusting
Old Aug 12, 2012 | 05:11 PM
Dazed's Avatar
thanks
Monstere316
Apr 2, 2011 06:06 PM
ebear
Apr 26, 2008 08:16 PM
patman
Mar 31, 2008 12:41 PM
rjporter
May 7, 2007 09:43 PM
SteeleCBR
Mar 23, 2007 03:57 PM
