Power commander 3
Old 05-21-2010, 11:27 PM
mtneyman's Avatar
i still got it if you want it...
but where do you get a map that keeps the MIL 34 and 35 off?
https://cbrforum.com/forum/showthrea...ower+commander
guess ill try a "full exhaust" map from pc's website.
Old 05-22-2010, 05:15 AM
bubba_finch07's Avatar
the full exhaust is going to load up in the low RPM range just a little FYI. To reset your computer take the pos. cable off set it against the ground for a hour or two, light should go away. HOWEVER, it probally WILL trip again, I dont have a manual in front of me but I think that is the servo motor gone bad. Probally carboned up. Even though the servo motor is just not hooked up to the flapper, or hetv valve it still needs to be able to turn and spin, If it cant it will through a light. Test it replace if need be. Or live with the light.
Old 05-22-2010, 07:13 AM
letsride's Avatar
Thumbs down
What you want me to pay for it AGAIN and YOU not send it again?
Old 05-22-2010, 07:23 AM
LOL nice. you get a strike on you in the seller category. boo! lol
Old 05-22-2010, 07:30 AM
letsride's Avatar
Yeah took "file a claim "from paypal to get my money back.Which only took 1 mo. to get.I wouldn't trust him at all.I was about to send him some stuff for free,but glad I didn't.If you still want those parts send me $170.00 and I might send them to you.
Old 05-22-2010, 07:50 AM
holy chit. thats scamming mate. MOD!! mod where are you? :banhim:
Old 05-22-2010, 08:08 AM
letsride's Avatar
Sorry about the thread jacking,now back to your original question.The o2 sensor can be removed if you want at anytime.Right now I'm running my bike without a pc(read above)flapper mod and no air scoops and is running the same.If you are planning on doing the htev valve I would wire it wide open(which is the marker pointing straight down)that way you don't have to gut the valve.Just remove the cables to the valve and zip tie them there.When you use your power commander map it to a full system exhaust or have it custom tuned.
Old 05-22-2010, 08:52 AM
skip954's Avatar
you should be able to rotate the servo motor back to the nutrel position and the fi light will reset itself. as for the pc3 any full system will be without the htev but probly will not remove the code.
Old 05-22-2010, 08:56 AM
letsride's Avatar
If the servo is bad it needs to be replaced for the light to go off.
Old 05-22-2010, 09:08 AM
skip954's Avatar
true im still half asleep this morning and only read the first page before posting..,
im a D.A.
did the prob. start *** soon as you did the htev mod or later?
also is it a cali bike o2 sensor if it is then im not sure i think there is a cali map that does away with the o2 sensor.. i'll look real quick
Quick Reply: Power commander 3
