OIL
Old Aug 7, 2007 | 09:34 PM
richhowerton's Avatar
Default RE: OIL
I have used the 10-30 moble 1 full syn and I have 38K on mine with no prob so far.
Old Aug 8, 2007 | 06:44 AM
eyesky2002's Avatar
Default RE: OIL
Read in a motorcross mag that Honda is putting out a new HP4 fully synthetic 10w40 oil....
Old Aug 8, 2007 | 06:58 AM
matty's Avatar
Default RE: OIL
Still no luck. I'm going to put some moble 1 - 10w30 inthis time around i think.
Thanks all!
Old Aug 8, 2007 | 07:06 AM
matty's Avatar
Default RE: OIL
OK OK.... I just called a spot and they have full syn repsol 5w40. How does this sound? And would you in yours?
Old Aug 8, 2007 | 07:55 AM
gixxereater's Avatar
Default RE: OIL
The weight of the oil makes a bigger difference than the viscosity. 5W - 10W - 15W, THAT is the weight of the oil, if you dont want to rebuild your motor I would stick with the 10W. The viscosity of 30 if it's full synthetic is more than sufficient. Drag racers use 0W- 20 or 30.......but they rebuild their motor after every run and are looking for every last ounce of HP to be had. Run the 10-30 and you will be fine.
Personally, to answer your question, no. I wouldn't, but then there are people that wouldnt use "car" oil either so........
Old Aug 8, 2007 | 08:29 AM
matty's Avatar
Default RE: OIL
Perfect. Thanks again. You've all been a great help!
Old Aug 8, 2007 | 10:07 PM
matty's Avatar
Default RE: OIL
Guys, just got in from the first ride after my oil change... holy crap! The full syn is 1000 times smoother shifting.
Thanks all!
Old Aug 9, 2007 | 12:06 PM
TCIRACING's Avatar
Default RE: OIL
Glad you found your piece of jewelry! Stick to the same brand oil, it'll get better and better.
