OEM front fairing material?
Old Feb 7, 2011 | 05:05 PM
rehed's Avatar
Default OEM front fairing material?
I have a '02 954 that has 2 broken tabs in the front fairing which attach to the headlight assembly and another 2 broken tabs at the headlight assembly attaching it to the fairing stay. I am considering glueing them and I think it's ABS but want to confirm before I get the glue. I've also read that ABS shavings mixed in acetone may also work. Has anyone done this repair before and know what works best?
Old Feb 7, 2011 | 05:25 PM
moosestang's Avatar
I would get some super epoxy or any two part epoxy that you have to mix together. It will bond anything together, trust me.
Ace hardware sells the super epoxy that i've always used and one tube will last for ever. I used it to bond the head of a metal bolt to the back of a plastic grille on my truck and it's still holding as far as I know(sold the truck).
Old Feb 7, 2011 | 06:53 PM
txsmainevent's Avatar
Plastic weld, the only way to go. None of that mix ****....
Old Feb 8, 2011 | 07:04 AM
mr manfringinsen's Avatar
If you look inside the fairing you will see ABS embossed on it. The side fairing are PP. There are plastic repair kits sold for body work shops. I picked up a 60ml tube of glue from one of them (Plastex) for AUS$10. The glue is ABS so it is like welding. Clean up back to raw plastic where you are going to glue with a dremel if possible, I know this is hard for the tabs, and clean before gluing with SolPrep, (Wax and Grease remover).
I only used Solprep on my tabs and glued them. Left them alone for 24hrs and they were strong.
Old Feb 8, 2011 | 08:09 AM
backdoc's Avatar
I just repaired a few broken mounting tabs on my headlight/front fairing this past weekend. Plastic weld from Advance Auto parts works great. It is a two-part epoxy but very easy to use. I have used it before to fix cracked fairings in the past with no problems.
http://shop.advanceautoparts.com/web...37_T%7CGRP2034____
Old Feb 12, 2011 | 08:24 PM
silvr002001's Avatar
you can also get liquid abs plastic at lowes
Old Feb 14, 2011 | 08:08 PM
rehed's Avatar
Default update
I used the Perma Poxy 5 minute plastic weld on the broken tabs. It seems pretty strong, but I won't know until after I install it and ride it.
Krux
F4i - For-Sale / Trade
16
Aug 11, 2011 05:56 AM
Jebbin12
F4i - Wanted
Feb 27, 2011 09:15 AM
kray923
Mar 17, 2009 10:11 AM
