Need help,bike bogging down
Old Aug 26, 2009 | 02:20 PM
rondrue's Avatar
Default Need help,bike bogging down
I have an 02 954,it seems to be not enough fuel or too much fuel,it starts and runs fine at first.after about 20 minutes,it smells real rich and boggs down at 50+mph, it never shuts off though. can anyone shed some light,ive changed the plugs and air filter,and ran fuel injector cleaner
Old Aug 26, 2009 | 04:24 PM
letsride's Avatar
Do you have a power commander?
Old Aug 26, 2009 | 07:26 PM
nikos's Avatar
I would guess a fuel pressure regulator. It's also possible that it could be an injector that is sticking... Hard to tell without digging in.
Old Aug 27, 2009 | 10:55 PM
CBRinPDX's Avatar
does the bike ever kick down from high idle when the engine warms up?
If not, you could still be in the enrichening circuit...
Old Sep 2, 2009 | 06:14 PM
svt954's Avatar
Default re:
is there a check engine code! when you start the bike and let it idle the red check engine light will blink a code. the long blinks are counted as the first digit the fast blink is the second digit. it will blink the long blinks first and the short blinks second. unless it is a single digit code it will only blink fast blinks. check that and you can get more help. mine blinks 3 long blinks right now and 5 fast blinks which is the servo motor code which can be referenced in a honda manual. check that out first.
conzar
May 22, 2014 03:09 AM
dan4011
F2 Tech
Aug 25, 2011 11:09 PM
rizoss16
May 1, 2010 08:34 PM
busyychild
Jul 30, 2009 11:20 PM
jayson_219
Aug 18, 2006 01:07 AM
