Looking for some tranny advice!!!
#21
#22
#25
#27
thats true... thats very true.
but an over-whelming majority of people that call themselves "mechanics" are people that can ONLY follow manuals. i understand the difference.
and while i know the people who are truly mechanics are the guys that know how to tweak, know how to make motors or other various components work better than they were intended to AND they're the guys that can diagnose problems, and figure out what's wrong and what needs to be done...
in the context of this thread, its replacing a worn tranny for a newer tranny in better condition. stock vs. stock.
follow the manual, use the tools needed - job done.
for the guy to come here and say, "no, you need a real mechanic with a "trained" eye tell you which gears are worn out" and then tell us to do something that is a VERY bad thing to do to a tranny (throw new cogs into a used tranny) IMO is wrong. and then to sit there and say, "i know because i'm a mechanic at a multi-line dealership" is also wrong. its arrogant.
.... i didn't mean to offend anyone. sorry for offending anyone that i did offend.
#28
okay, i understand you don't want to build a new tranny. the reason for that being its not cost effective at all. its like this. if it comes into the shop with a (slips out of 2nd). you could replace every part in the transmission, and it would fix the problem. but that would cost a fortune, for the customer and the shop, so a mechanic comes along, finds the parts that are actually causing the problem and replaces it.
but look, this guy diagnosed the problem, its not slipping, he just doesn't have 4th anymore. and the same thing is happening with 2nd. now if you look at the repsol build page. you'll see this pic
![Name: IMG_1206.jpg
Size: 92.1 KB](https://cbrforum.com/forum/attachments/cbr-954rr-21/45290d1501285192-looking-some-tranny-advice-img_1206.jpg)
as opposed to just removing the parts that are damaged (those 2 gears), i replaced the entire transmission. the reason being is there is a wear patern on the gears (think like chain and sprockets). if you throw a different rear sprocket on a chain/sprocket set that has a few thousand miles on it, it'll wear WAY faster than it would normally - because of the wear pattern.
its the same with the transmission. you could easily replace the worn gears with brand new OEM factory honda cogs, BUT, the other gears plus the new gear will shift bad, and wear much much faster.
instead, putting a slightly used transmission in here instead (that already has its own wear pattern) is a better bet. here's this motor getting ready to go back together. every component in the tranny is the OTHER transmission. shift forks, shift drum, shaft, counter shaft, all of the gears - EVERYTHING. it all works together.
![Name: IMG_1474.jpg
Size: 3.7 KB](https://cbrforum.com/forum/attachments/cbr-954rr-21/45291d1501285192-looking-some-tranny-advice-img_1474.jpg)
now, if your customers found out that you were buying used trannys off of ebay and putting them in their bikes (even though its a better solution to a transmission issue like i've exampled here), they'd flip their **** and never come back, so you bet that no dealership would ever do what i did. but, if you get a tranny that is in good shape, its a better solution.
if you get a tranny off of ebay, and its in bad condition, and doesnt work for you after you've inspected it - send it back, get your money back, and look for another one.
#30
